996 Forum 1999-2005
strut/shock?
Old Dec 27, 2017 | 06:05 PM
Hurdigurdiman's Avatar
Hurdigurdiman
Default strut/shock?
I took my car for its annual test and found that the left rear strut/shock is leaking. I need to replace both of them. I am struggling as to what I should order. I would like to get them from Pelican parts but what do I ask for? The whole thing including the spring etc. or simply the part that is leaking? If you know of a better place than Pelican then please tell me. In other words, what would you do in my position? Thanks. A few recommended links to what I really need would suffice.
Old Dec 27, 2017 | 06:52 PM
ejdoherty911's Avatar
ejdoherty911
Year? Model?
Old Dec 27, 2017 | 07:19 PM
laphan's Avatar
laphan
You can replace the struts only. Check the bump stop condition, mine were about to disintegrate when I r placed my struts.
I went with Bilstein B8 option. I think B4 is direct factory replacement, B6 is heavy duty and B8 is sport (normally for lowered suspension).
Koni is another good option.
How are the 2 fronts doing? If they are not in good shape, you can consider the M030 or X74 option.
Old Dec 27, 2017 | 08:41 PM
Hurdigurdiman
it;'s a 1999 rear wheel drive carrera.
Old Dec 28, 2017 | 12:47 AM
longrowe's Avatar
longrowe
If you want specifically from pelican, here is the shock only page:
https://www.pelicanparts.com/catalog..._pg1.htm#item0
as stated above, B4 is OE, B6 Performance and B8 is for lowering springs.
Old Dec 28, 2017 | 01:19 AM
Ahsai's Avatar
Ahsai
I would also recommend the ROW M030 set ($1.6k from suncoast porsche) as it has a lot of values. Definitely replace the bump stops.
https://www.suncoastparts.com/product/ROWKITS.html
Old Dec 28, 2017 | 08:28 AM
DBJoe996's Avatar
DBJoe996
Definitely a good time to replace the upper strut bearings as well.
Old Dec 28, 2017 | 09:49 AM
cds72911's Avatar
cds72911
It would be helpful to understand what you want to do - just a stock replacement or something else? How do you use your car - street, autocross, track events, etc. Do you want stock handling, more stiff, stock ride height, lowered?
Old Dec 28, 2017 | 11:30 AM
Device2's Avatar
Device2
I concur with cds72911, it all depends on that you want to do with the car's handling and performance at this point since you have to replace those rear worn shocks.
Old Dec 28, 2017 | 12:48 PM
Sneaky Pete's Avatar
Sneaky Pete
Hurdi......I have a used rear shock from my 996. It has about 60K miles on it. If you want it just pay me shipping.
Old Dec 29, 2017 | 04:51 AM
Hurdigurdiman
Added later on second thoughts.
Pete I have decided to take your offer on the rear shock/strut/ as only one of mine is leaking. how much is the shipping and send me your email address so I can send it to you via paypal. Thanks again.. Mike Grogan
234 stephen lane, Ephrata PA 17522.
my email Mike@ex-lancs.com
I sent you a private message as well.
Old Dec 29, 2017 | 03:42 PM
Sneaky Pete
Just sent an email to you.
Old Dec 29, 2017 | 06:06 PM
laphan's Avatar
laphan
Well, I have a set too that you can have for shipping cost if arrangement with SneakyPete does not work out. Offer opens for anybody who wants them too.
Mine is a bit higher in mileage, I think around 80K when I removed them. They work fine when removed 2 years ago. They are removed because I lowered my car with techart springs and bilstein B8.
Old Dec 30, 2017 | 05:39 AM
Hurdigurdiman
thanks for the offer Laphan but I doubt i could use them as mine has done almost the same milage as your car. 92000. Mike
Old Dec 30, 2017 | 09:38 AM
dporto's Avatar
dporto
The best price/availability I found on Bilsteins was from TireRack. I tried to buy them from someone else but they only sent me one - with no promise on when I’d get the other...
