DIY A/C bracket modification for ease of belt installing
-Problem: It seems Porsche NA engineered tolerances too tight to allow easy changing of fan belt on some of the 993TT. As a result, one cannot easily remove and replace fan belts due to clearance issues between the innermost pulley and the AC bracket found on the right side of the pulley at exactly 3 o'clock
-Solution: Hack-saw off this AC bracket corner and clean up with a metal file
First photo: This is the problem: Belt too large to clear pulley; to the left of that 17mm nut
Second photo: This is the tool you will need. Purchased at Lowe's
Third photo: Job about 1/3 done. See slice into bulky bracket; remove 17mm nut to allow improved access
Fourth photo: File used to clean amputated part
Now belt goes in the honest way without stress. Note bracket is still solid and does not seem to compromise integrity
Last edited by ttAmerica RoadsterAWD; 12-13-2012 at 03:38 PM. Reason: I suck at posting
Porsche's recommended procedure on their TSB:
http://www.pcarworkshop.com/images/e...0595geolab.pdf
Cheers,
Mike
Cheers,
Mike
Cheers,
Mike
Cheers,
Mike
is it me or is something strange about the tsb
date of issue 21 november 1995 models affected 1996 911 turbo
pfp porsche foward planning
