amazing car...RUF Turbo R
#271
#274
http://www.crutchfield.com/p_113KDCX...-KDC-X996.html
after a lot of research this is what I went with, great features, power, ipod connect, etc... plus most important green illumination color option that matches the green RUF gauges almost perfectly![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
#275
So far happy with the look.. Black leather RS style door panels (they have a vinyl option) I went with a shallow mount infinity speaker set up with perforated speaker grills to avoid having to mount grills etc... and as seen a blue pull to match interior. I have black and red pulls if I decide to ever change.
#276
Like the black RS panels Mick ! Nice balance with the interior blues....
Noticed you changed your calipers to the yellow RUF calipers. Did you get these from RUF USA in Michigan or directly from the factory ?
Geoff
Geoff
#279
Wish I was there..... Turbos should be back from rebuild soon, (hoping early next week) then engine goes back in, some tweaking, full alignment+corner balance etc, stereo head unit etc, then I get the car back and from there off to have the skirts removed...they are coming off that is certain.
#285
My shop is ultra finickly in a good way, they like things done right, 100% and things that are quality...... they said this carbon fiber was excellant, fit was TOP notch on all pieces. I highly recomend Marcus...the carbon weave is spectacular, its has nice color to it, a hair darker then OEM stuff and IMO a better finish. (maybe because it is new and most stock 993 carbon OEM dashes have seen near 15 years of wear/fade/use etc)..... Its a bit of a project to install but real happy with the results.
