Fun while it lasted
Fun while it lasted
Well, last weekend I finally got my car put back together after my myriad of winer projects. For those playing the home game, I had a series of leaks that I wanted to fix, including cam gaskets, timing chain gaskets, and puddling under my turbos when parked.
After some research on RL (and a few chats with several of you), I decided to install UMW's check valve kit to stop the oiling problem on the turbos, and thought my issues would be solved with a new oil filter. Not so.
I drove the car for 150 miles or so the first day but was a little alarmed that the oil level never registered on the gauge. I checked the oil level on the stick when I got home and it read half way, so that felt good. I then went in the house for dinner.
After coming back out a couple hours later, I had 3 pools under the car. W under each turbo, and one under the intake pipe on the driver's side. So I now realize that I have either a bad oil filter or a blown turbos.
I'm going to try another oil filter this weekend, but hold little hope. I talked to Kevin, and he's thinking my turbos are toast.
So, I now need to decide what level of work to be done...stage 1 or just straight rebuild. I'm leaning towards the rebuild, because I like originality, but who can argue with extra power?
I went through this almost a year ago - went with protomotive hybrids w an ECU reflash. Cost a bit more but if you are already going in for a few $k on rebuilding your stock turbos, why not spend a bit more to give it a more power
https://rennlist.com/forums/993-turb...rade-kits.html
As one who has been to Stage 2 and back again, I would suggest you think very carefully about what you are looking to do with the car and what your real needs are. We know that Stock will always hold value better. A stock car is no slouch and few road driven 993TTs cars will ever be able to realy use or need more power. Sure, if you want straight line drag pace, OK. At the track, 100HP = 70Kgs. In other words, there are cheaper ways to go fast like weight reduction, suspension, aero etc. Also think carefully about heat and fuel. More power means more heat, and a greater risk to the engine if ambients are high or your fuel octane is suboptimal. I've learnt that in hot climates race gas becomes manditory to avoid detonation issues despite knock sensors and monotronic "protection". It all sounds tempting, but think carefully. Like going to war, its easy to start, hard to stop.
Sorry to be a wet blanket!
I would offer you really need to understand the source of the leaks before you spend more money... not that a power upgrade is a bad thing! But it if have issues outside of the turbos then they'll still be there after the upgrade.
Clean things off with loads of brake cleaner and towels to get things spotless (the oil creeps and gets blown everywhere making tracing a leak difficult) and then run the engine up to temp, ideally some place where you can see things from up above and down below and make sure your timing chain cover and cam cover gaskets are leak free. Also check the connection between the check valves themselves and the turbos - one of mine began to leak after a few thousand miles and needed to be resealed.
If you haven't got a leak when the engine is running try this test: get the engine good and hot and shut it off, remove both turbo sump drain plugs and see how much oil drains out over time. It should only be a small amount that comes out initially and then it should stop. If it continues to run out then either your check valves have stuck open (v v unlikely) or oil is being siphoned back through the scavenge lines.
What oil are you using?
All in all, I'm a cheap b@stard, or I wouldn't do my own work...but I'm also **** and want it perfect too
I'm using Wal-Mart 5w30...is that bad? Just kidding, I'm using Redline 10w40 currently, but I'm not sure what that will have to do with leaks. I'm thinking any oil is gonna leak from the puddles I've seen. Unless I'm missing something?
That oil is a little on the thin side - I think Mobil 1 15/50 or the Mobil 1 V Twin oil is what a lot of people in the US use. But the thinner oil shouldn't be the root cause of your problem, just something that might exacerbate it.
