UMW Stage 2 and Stage 3 "drag race"
Greg H and I got a chance to play at Thunderhill on Friday and compare Kevin's Stage 2 and Stage 3 (still in development) turbos.
http://www.youtube.com/watch?v=Vurcy6MMLgE
Kevin's new turbos (Hi-Flow K24 turbine and 997 GT2 compressor). The engine also has cams and is sans cats, and has built internals and solid lifters. See this for more info: https://rennlist.com/forums/7030409-post23.html
You're going to want this to keep up with your friend with the GT3 RS
I need it to keep up with Greg!
This time I was using my Chase Cam setup (the GPS module on my other setup was not working).
But yes, the rear camera angle was different because I didn't have a roll bar mount with me, but I did have a suction cup mount so I stuck it to the back of the GT3 seat, which are smooth as glass so it worked fine. Previously, I had the camera mounted on the ceiling (due the mounting system it uses).
