Possible to add 996 center console?
Would it be physically possible to add the center unit even if modified to the area between the dash and the switches? It would be great if so to add a nav screen. If not is there a kit or something for such a provision to add the nav screen? I know techart had one back in the day but I only want a housing, hence the thought of using a 996 lower center console to shove a double din nav in there. Even if I could get 1 single din slot that would work as well because I could then use a pioneer flip out without hitting the dash (my main problem).
Here is a link to the kit- you can also Youtube kenwood dash kit 996 and see the install.
http://cgi.ebay.com/New-99-02-Porsch...ht_2286wt_1167
