RS Uprights
RS Uprights
Here is a picture of the RS upright next to the stock upright that is being installed on Andi. As you can see, it raises the spindle, which lowers the car while still maintaining all of the original shock/spring travel. RS tie rods are also required. They have a slightly different geometry as well. I'll try and get a side by side of those as well.
Scott: The project is actually moving forward. Some new hats are being machined on the 15" brake rotors to solve a clearance issue and then we should be in the home stretch.
Geoffrey: This will be a street only car, so I did not want to go too radical and I like to use OEM as much as possible.
Vincent. When our cars are lowered a lot using the method of adjusting the spring perches, there are two negative side effects.
The car becomes subject to bump-steer issues in fast sweeping corners due to 1).suspension tie-rod geometry changes and 2).reduced suspension travel.
The factory uses these parts on the RS cars to lower the car whilst maintaining proper geometry and suspension travel.
Geoffrey...
I've got the Evo uprights on a 964 but it uses the standard 993 inner tie-rod along w/the RS outer tie rod (and yes the inner had to be cut about 1/4 to 1/2 inch to fit). It still seems to have issues w/caster and centering the car...at speed. Running:
-1.4º camber
3.2º caster
-0.01º toe
Do you think there is any difference running the inner motorsports tie rod than the 993 oe inner tie rod? This mix/match came from Smart or one of those places as a "kit" for the evo upright. I know the motorsports inner tie rod has a solid ball joint, but does that mean it has a different pickup point that would affect the highspeed centering issue? In the twisties it is simply brilliant, just working to get it to center better at over 80mph.
Suggestions?
-1.4º camber
3.2º caster
-0.01º toe
Suggestions?
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Geoffrey...
-1.4º camber
3.2º caster
-0.01º toe
Suggestions?
-1.4º camber
3.2º caster
-0.01º toe
Suggestions?
Maybe increasing caster, if possible, would help? 3.2deg seems low(?).
