993 Turbo Forum 1995-1998
Ride height for 993 Turbo S
Old 11-18-2007, 12:54 PM
LAT
LAT's Avatar
Default Ride height for 993 Turbo S
I am in the process of buying a 1997 Turbo S and installing PSS9 struts.
Question - What is the correct factory ride height?
Facts - The Porsche manual states that the ROW ride height for the S is the same as the regular Turbo. However the articles and reviews from that period mention that the car was 15mm lower than the Turbo.
P. eclou, now you know....
Old 11-18-2007, 01:22 PM
eclou
eclou's Avatar
Received 1,236 Likes on 606 Posts
Wow, congrats!! That makes 3 993's in the garage? How long before it is www.LATsportscars.com?
Old 11-18-2007, 03:35 PM
Jean
Jean's Avatar
LAT
You might be comparing ROW Turbo S vs. US Turbo which was higher than ROw turbo.
The information I have shows them as being the same height.
In any case, you need to take it to RS height, and be sure you do the corner balance after installing the PSS9s.
Old 11-18-2007, 05:36 PM
LAT
LAT's Avatar
Jean
My info shows;
Based on the same measuring point of A for the front and B for the rear
ROW Turbo and Turbo S - Front 144mm - Rear 127mm
USA Turbo and Turbo S - Front 174mm - Rear 157mm
RS ROW only - Front 124mm - Rear 107 mm
Is the RS height not too low for street use?
LAT
Old 11-18-2007, 05:43 PM
Jean
Jean's Avatar
Originally Posted by LAT
Jean
My info shows;
LAT
LAT, I have the same info for ride height..They (TT and TTS) are the same height.
The RS height is perfect for street + spirited driving + looks. There is some tolerance acceptable, you can set it to say 130mm in the front.. When you do the corner balance, all of this will be approximate.
Old 11-18-2007, 07:53 PM
IamSMC
IamSMC's Avatar
Some info here
http://p-car.com/susfaq.html
Old 03-05-2013, 05:52 AM
geolab
geolab's Avatar
Sorry to revive the thread,
ROW Turbo S is 17mm lower than the ROW Turbo and all suspension bushings are RS hardness (85 shores) from the factory.
Front is 127 mm - Rear is 110 mm
At the introduction of the Turbo S in Europe, all improvements or differences with the ROW Turbo, were offered as an upgrade option.
The ROW Turbo S chassis setup from Factory is mounted with option X73.
The original ROW Turbo S struts factory mounted, were the exact same Bilsteins on the Carrera RS
Factory ROW Turbo S alignment settings differ slightly from the ROW Turbo alignment settings.
Old 03-06-2013, 06:52 PM
mausone46
mausone46's Avatar
15 mm lower and uniball, which make the car harder
Old 03-06-2013, 09:24 PM
chsu74
chsu74's Avatar
I thought you would get bump steer when going RS ride height unless GT2 uprights are installed?
Quick Reply: Ride height for 993 Turbo S
