Switchable ecu programs for 993tt?
Ahh, Kevin is this the 'new tuning alternative' or something like that for our cars - that you mentioned / teased us about in a post a while back? If so, Great! I just changed my MAF recently and did the plugs today in anticipation of more go good goodies in the near future!
Any ECU from Kevin is excellent. It runs great a .8 or at 1.1. However gas is always an issues especially here in Cali....and you may not have the octane in the tank all the time to enjoy the 1.1. A simple boost controler...which to Kevin I know is a big "no-no", but I think that's because people crank them way up and run 1.3-1.5 for fun and smoke their motor...but used sensibly as a "fuel program" only, I think its a great alternative. You an set a .8 program and a 1.2 or 1.1 program. You can also dial in the "gain" or how the boost comes on if you want. But used in this fashion, you still get all the benefits of Kevins great ECU and can have two seperate fuel programs. Kevin may not agree w/that, but I've seen it used that way by a few people here and it seems to be a viable alternative to having two separate ECUs being popped in and out on these old systems. Just a thought.
A boost controller means fixed boost though doesn't it - i.e. lose motronic control...
Perhaps even better is a true map switcher as the first thread suggested - still a switch but not analogue, it has 3 or 4 settings and moves between 3 or 4 motronic maps....from 0.8 bar up to whatever.
This could be used in the same way for poor or better gas.
I was very interested in this solution sometime back when I was struggling with getting the best optimized program for my intended usage…This is something every one of us, owning a dual purpose street/track car, would like to have.
I would say that there are two ways of doing this on a Motronic based car, and you also have the option to go for a different solution with an aftermarket ECU such as Motec, Thielert etc..
Some European (and US, such as Autothority) tuners had already done this many years ago, by having a device (sub $100) that takes two chips (or three or four) and links them to the DME box and then you have a simple switch on the dashboard that would let you choose between programs.
A friend of mine with a Manthey 993TT has this setup since the late 90’s. It works flawlessly until today. So when he has race fuel, he switches to kill mode (500+HP), and when he is on pump fuel, he switches to another milder tune. I found a couple of suppliers during my search but never ended up buying the device. This is a great option and inexpensive solution that gives you flexibility to use the programs of the tuner of your choice rather than being limited to one tuner...
Another more modern solution is the device that has an interface, memory and a processor all in one little pocket sized plastic unit, that would alter the data in your engine controller through the OBDII port, which is I believe what Kevin and his supplier have more or less. I also heard of another tuner having somewhat similar devices who might be working on such a project for our Porsche cars.
Let's hope we see them in the market soon!
You can have your tuner program two different chips ($10 per piece cost of the blank chip) for your car on the dyno and then simply pin them into the device (read Manthey solution above) that takes two chips linked to your ECU box, with a switch on the dashboard. The programs can be Motronic boost controlled or not regardless, it depends on your tuner.
Yeah that's what I meant Jean - personnaly I wouldn't want fixed boost on my car, whether it was controlled by me in the cabin or not.
The multi motronic map/chip solution would be great - not so much for fuel in my case as the UK has high octane all over the country....more for different uses like you said earlier - street, track etc.
I love how the standard 408bhp car puts its power down - even in the wet, the power doesn't dominate the car like a higher boost RS tuning chip I had for a while. For me personally - it would be great to switch between a say a motronic 408 and something higher for the track or when it's dry.
