Cooling down turbochargers?
I understand that 993TT needs a little cooling off time after running hard. How long should I let it idle after normal brisk street use with a few full throttle apps? Is pootling down my neighborhood streets for 60-120 seconds enough cooling time, or should I let it idle in the garage for a little? What about after a fast drive through the hills?
I've always been an NA guy, so don't know the drill.
Thanks,
Bill
Thanks,
Bill
Try to get into the habit of 2 minutes.. 1 min minimum in all situations/conditions. Not only are we lowering the temp of the turbine housing, but as these cars age, the ceramic liners/heads benifit from the reduction of temps.
Marc
I cool for 2 minutes as well...but I don't have mufflers....so I shut the garage door. Thankfully its a detached garage. Its when I leave at 6 am on the weekends for spirited drives that I think the neighbors mind the most...
