100 octane fuel
The 91 Turbo has an older CIS injection system and prvovided it has been set correctly and the engine is stock, running stock boost, the same applies.
I'd offer some different experiences,..........
Temperature plays a BIG role in detonation thresholds (knock-sensor activity) with our 92 octane pump gas and I've observed significant power changes on a chassis dyno between 92 & 100 octane fuels on stock as well as modified TT's.
You can easily feel the difference on the track, especially on a warm day,...
Indeed, its been awhile,.....
I'm glad you are pestering 'ol Joel as he needs the "exercise",...LOL.I cannot explain why others say that 100 octane fuels are a waste of money here; perhaps these kind folks do not own/drive these air-cooled turbocharged cars and have no idea how sensitive the 993 TT is to outside air temperatures, cylinder head temps, charge-air temps and oil temps.
There actually is such a thing as too much octane. Higher octane fuels burn slower and timing timing needs to be set accrodingly. Additionally, there is much more to fuel than the octane rating which is the most abused number relating to fuel quality.
I realize I'm in the minority here, but I do have factual experience.
I understand that there is more to fuel quality than octane, but for most of us, the only hope of improving quality is to toss in some 100 octane available at the track. I have no clue how else to get qood quality other than this; I have to assume that the race fuel at the track is about as good as it gets unless you start "home brewing"
The air temp effect on the ECU is something I hadn't considered before; I had always assumed the ECU used the knock sensors as the primary mechanism for reducing timing. I'd assume it is looking at intake manifold temps, after the intercooler; is that correct?
Thx
I guarentee that Porsche tested the 993tt on 91 octane fuel on a race track under extreme temperature conditions as part of the ECU development program. Further Porsche tends to be conservative which is how companies like Protomotive can enhance the performance. Race fuel in a stock car is a waste of money.
I have over 25k track miles of data logging from my personal 911 Turbo spanning 8 years not to mention the number of turbos I've done. In fact, just this weekend I just finished up a stock 996TT GT2 engine with a MoTeC M600 ECU controlling the variable cams which will be run at the Road Atlanta club race. And believe it or not, it can be run on 93 octane fuel and made 460rwhp@.55bar of boost. HP was limited due to the stock bottom end.
I think you bring a wealth of experience in tuning EFI to this board, but I will humbly dispute some of your statements to which I do not agree.
The knock sensors are not overstated, they are THE major advantage of Motronic vs. any aftermarket EFI system out there including Motec.
In the 993, they are mainly for protection, but on the 996, they are used to push the limits of tuning to its thresholds, since they can provide you with excellent feedback, you can watch the timing that the ecu runs and recalibrate accordingly without damaging your engine.
Motec will give you better results than Motronic if you are not able to access the codes needed to have a proper calibration, however a good Motronic tuner will certainly maximize the engine's potential 10 out of 10 times better than Motec, specifically with the help of the knock sensors. Another reason why world leading teams in Porsche racing all use Motronic, not Motec, for anything other than datalogging.
Concerning the numbers you are getting on the 996GT2 engine, I have seen them written in a couple of places on the board. It makes me wonder...Todd Knighton of Protomotive who is a well respected builder, built what is arguably the fastest 996TT in the US (not to say on the planet) running 9s quartermiles with 3800lbs of weight all day, it took him about 18 months or so of programming, calibration and testing to reach the levels of performance that he did, used very efficient turbos, did massive work on heads etc..and reached only 538 FWHP at 0.63 Bar or so on race fuel on his engine dyno. How were you able to achieve better numbers with so little, 2 hours of tuning and stock internals?
Something is wrong Geoffrey.If you ask Todd, he will tell you knock sensors were fundamental in reaching these levels and safekeeping the engine.
Food for thought.
