993 Turbo Forum 1995-1998
The Ultimate quest for 8500 RPM engine build
Old 02-27-2006, 08:27 AM
  #76
Geoffrey
Geoffrey's Avatar
Isn't that the same guy who built the 9300rpm 800+hp 3.3 Turbo engine?
Old 02-27-2006, 10:48 PM
  #77
Rickard 993 Turbo
Rickard 993 Turbo's Avatar
Do you mean this
http://www.spezialmotorer.com/start/...a_sprint_1.htm
Old 02-28-2006, 03:58 PM
  #78
Woodster
Woodster's Avatar
HOLY S*#T,
How many LB/FT of torque is that?
Who is the builder and what car did it go in?
What level of comedy was achieved upon driving the car with that motor in it?
Marty
Old 02-28-2006, 05:19 PM
  #79
Geoffrey
Geoffrey's Avatar
Thats the one.
Old 02-28-2006, 05:44 PM
  #80
Kevin
Kevin's Avatar
Did you guys see the factory coils and 964/993 distributor..
Old 02-28-2006, 10:20 PM
  #81
Rickard 993 Turbo
Originally Posted by Woodster
HOLY S*#T,
Marty
840LB/FT
Micke Svens here in sweden at Spezialmotorer,one of the few that have worked on 962 and gt1 engiens
Do not know what car it vent in, but it's a race car iknow
Old 03-01-2006, 12:22 AM
  #82
Jean
Jean's Avatar
The same on the FVD/MODE engine that Tal showed a couple of weeks ago, and so many other high HP ones..
Old 03-01-2006, 10:16 AM
  #83
Miles965uk
Miles965uk's Avatar
Cool thread...
What plugs are you using Jean? You think the stock ones are crap all togther or crap from XXXHP onwards?
Anyone know the real cost of getting a CF installed - just courious
Old 03-01-2006, 10:33 AM
  #84
Jean
Jean's Avatar
Miles, I am using Denso plugs. I think each engine and its state of tune requires different ignition setups, there is not one that works everywhere. In my case, the Denso really woke the engine up after a certain limit was reached.
Old 03-01-2006, 02:17 PM
  #85
Geoffrey
Geoffrey's Avatar
Jean,
Your denso plugs have a very small electrode .4mm if I recall and do not require as much energy as other plugs (especially the factory 14FR6LDU plugs). I suspect that if you installed the factory plugs, your engine would drop in power and/or begin to misfire due to the increased demand on an ignition system that is not sufficient for its application.
Old 03-01-2006, 02:38 PM
  #86
Miles965uk
Miles965uk's Avatar
Thanks Jean.... nuggets of useful information!
Old 03-01-2006, 02:56 PM
  #87
K24madness
K24madness's Avatar
I am using the denso's as well. IK22's I believe. The CDI did seem to improve the smoothness of my car FWIW.
BTW Jean nice graphs in the 4wd thread!!!!!
Old 03-01-2006, 03:29 PM
  #88
Geoffrey
Geoffrey's Avatar
Yep, IK22s would be the right Desno plug with an Iridium electrode.
Old 03-25-2006, 02:53 AM
  #89
Kevin
Kevin's Avatar
Last week I received my heads back from getting twin plugged. Please remember that there is alot more work that needs to go into these heads so I am posting this as I go through the process. Many folks don't only see the before and after, and really don't see the time or the multiple steps in the process. As you can see in the pictures there are sharp edges around the new plug in the chamber. I will spend time rounding the blending these sharp edges to match the factory recess. Please note the exhaust seat pitting that has occured.
This following picture shows the factory plug hole
The top five fins have had enough material removed to provide access for a spark plug socket.
The heads have not been surfaced yet. I won't surface and cut the sealing ring groove till all of the other machine work is done. This is done to avoid any knicks or scratches. They are off getting new guides and seats installed with larger lightweight valves.
A small detail, out of 12 exhaust studs, I broke 4 flush with the surface of the exhaust port. 3 studs were extracted with welding a washer and nut.. The fourth one needed to be drilled out and required a time cert.. Harsh winters do aid in corrosion. Plan for at least 1 to 4 studs that break off requiring more money spent in removing them..
Old 03-25-2006, 01:04 PM
  #90
viperbob
Former Vendor
viperbob's Avatar
Very nice Kevin.....
Quick Reply: The Ultimate quest for 8500 RPM engine build
