Wheel bearing?? or what is wrong??
On the race track today and my car started to make a "thump, thump, thump' noise that would only be heard from inside the car on right hand turns. It was coming from the passenger side rear wheel area. Wheel bearing problem??
Thanks,
Thanks,
Check:
https://rennlist.com/forums/993-turbo-forum/30751-binding-rubbing-noise-coming-from-the-front-passenger-side-tire-area.html
https://rennlist.com/forums/993-turbo-forum/205445-noise-the-track-experts-needed.html
https://rennlist.com/forums/993-turbo-forum/206548-suspension-noise-solved.html
Also, check you tires if they are getting worn.
Is the noise dependent on the RPM, speed or vibrations?
Noise is dependent on speed, not RPM. Only passenger rear on right turns and I did have a little off track excursion during that race that maybe loosen up something??
I'll check sway bar link.
