993 Turbo Forum 1995-1998
K16 Hybrids installed
Old 05-19-2004, 12:33 AM
mb97tts
mb97tts's Avatar
Default K16 Hybrids installed
Well I just picked up my car after having Kevin's k16's installed. The grin on my face took longer to go away after driving than it normally does!! So I guess they work?
No really, the car is definitley more alive. It responds instantly to the foot!!! Going out driving tonight minus the joke we call the 405 fwy.
Thanks Kevin!!!!
Marty
Old 05-19-2004, 01:58 AM
ca993twin
ca993twin's Avatar
Marty,
Did you do the GT1s (k16/k24 hybrids)? Did you do the Stage 2? Do you still have the stock ECU? This conversion is definitely in my future... still trying to firm up my options. Thanks
Old 05-19-2004, 02:44 AM
Kevin
Kevin's Avatar
Steve;
Marty is still out driving the wheels off the car. Seriously, He has the GT1's with his stock "S" ECU..
Old 05-19-2004, 02:50 AM
Bill P.
Bill P.'s Avatar
Marty, what are your driving impressions? Do you find power coming on at lower rpm? Let's schedule a trip to La Jolla for lunch. We'll trade cars. That way you will better appreciate what you've got.
Bill
Old 05-19-2004, 02:55 AM
mb97tts
mb97tts's Avatar
Just got back! WOW! Man what a difference! My girlfriend said it was like the car was pulling wheelies! The car feels like it wants to jump out of my hands. And for the first time I broke the tires loose in first gear.
Just like they said. "it makes the car come alive"
A very happy TTS owner tonight. Now I need driving lessons. ( like I didn't before)
Steve, Like Kevin said my car is stock S ecu. I think this is all I can handle for a while.
Mark H did the install. Car is running great.
And the car even sounds better.
Marty
Old 05-19-2004, 02:58 AM
mb97tts
mb97tts's Avatar
Bill,
Response is right there. First and second gear redline real quick. Let's get together soon and you can see if you notice a difference. I think you will.
And you have a great car that anyone would appreciate.
Marty
Old 05-19-2004, 08:04 AM
John H. in DC Area
Lifetime Member
John H. in DC Area's Avatar
Thanks for the post, Marty, it's reassuring as my GT1's from Kevin should be installed by the end of the week. Did you/your shop follow the detailed break-in procedure?
Old 05-19-2004, 10:44 AM
Mike W
Mike W's Avatar
Can someone post the cost of the hybrid turbo's. Are any other modifications needed? thanks Mike W
Old 05-19-2004, 11:12 AM
viperbob
Former Vendor
viperbob's Avatar
Along with hybrid turbos you can do zero clearance (greater efficiency), billet wheels (aluminum or titanitum) and backplates, porting the wastegate and inserting a larger flapper door from the K24s, and ceramic coating the turbine housing to keep heat (and energy) turning the wheel. Prices can range from around $800 - almost $2K per turbo for the work.
Old 05-19-2004, 11:17 AM
Corte Loco
Corte Loco's Avatar
Can be used with stock ecu or need a reprogrammed?
Old 05-19-2004, 11:26 AM
viperbob
Former Vendor
viperbob's Avatar
Hi Jorge.. How is the weather in Panama these days??
The ECu should be modified to take advantage of the new turbos. Otherwise the boost, fuel maps and timing will not get these baby's where they need to go....
Old 05-19-2004, 12:15 PM
Kevin
Kevin's Avatar
I think shortly we are going to have to organize a group buy for tires...
Old 05-19-2004, 03:11 PM
OldGuy
OldGuy's Avatar
Bob do you have yours in now??
Kevin lets do a group buy on Kevins Turbos!!
Old 05-19-2004, 03:21 PM
Bill P.
Bill P.'s Avatar
Great idea, OG. This sounds like a great upgrade. Does anyone see any down side to doing this. longivity, etc.??
Bill
AKA: ROG
Old 05-19-2004, 05:00 PM
Corte Loco
Corte Loco's Avatar
Hello Bob, right now is a rainy season so itīs almost impossible to go out with my car, still waitting for a sunny day to test my car with the mufflers bypasses and the ecu from Todd. I sent you several emails, did you received it? Thatīs all for now with my legs chaking to press the accelerator of my car, letīs see what the weather says!!!
Quick Reply: K16 Hybrids installed
