993 Turbo Forum 1995-1998
Lost clutch today
Old 05-03-2020, 07:44 PM
chsu74
chsu74's Avatar
Default Lost clutch today
Was on a run and down shifting. All of a sudden pedal hardened up and can no longer shift into gear.
I was at an intersection and able to start it in gear and limp into a fuel station across the street.
Any collective wisdom os what the issue is?
Old 05-04-2020, 01:31 PM
Mike J
Mike J's Avatar
If the pedal does not go to the floor, I doubt if it's the rubber line or lack of fluid - they usually fail by losing pressure, squirting fluid all over, and your pedal is on the floor. Do you have the hydraulic assist slave (ie stock one?). You check both the p/s and master cylinder reservoirs? If the assist slave fails, they can get super heavy. I had a p/s hose failure on a road trip one time, I had to cut the p/s pump belt in the field so I could limp home (a couple of hundred miles and a ferry), steering was super heavy and so was the clutch, but it still worked. Does your work with a lot of pressure, or its totalled?
Cheers
Mike
Old 05-04-2020, 02:41 PM
Kevin
Kevin's Avatar
Sounds like you have a failed clutch slave or clutch fork/throw out bearing failure. If you have 10 plus years on your pressure plate>> your pressure plate might be cracked (this will produce a stiff pedal and won't allow the any clutch movement)
Old 05-04-2020, 02:50 PM
chsu74
chsu74's Avatar
Thanks for responses. Looked under the car and no fluids behind front driver side wheel or on the gearbox. Think hydraulic lines are intact. Will a cracked PP or bad clutch fork allow normal shifting movements?
I have 105K miles. Complete top end and LFW, PP and clutch replaced at 90K miles but more than 10 years ago. I have driven the car since 93/94K miles.
The slave cylinder has not been working right since ownership. It was one of those replace when I need to drop the motor at some point. Clutch pedal is hard when motor is not running and soften right up after starting up. Thought that is the symptom with clutch slave and can still run..
What PP setup is recommended if I need to go down that road? Need something heavier? Stock ECU but with LWF..
Old 05-04-2020, 08:19 PM
Kevin
Kevin's Avatar
Sounds like a failed Slave and a failed accumulator (which will impacts your clutch pedal) You should have a soft pedal even with the engine off. A good accumulator will require 15 pedal depressing before it gets rock hard.
For a stronger Pressure plate> I would go with the Sachs Race 764 or the stock turbo plate IF you aren't tracking the car. I have linked a few clutch kit options..
http://ultimatemotorwerks.com/clutch.html
Old 05-04-2020, 08:33 PM
chsu74
chsu74's Avatar
Thank you Kevin!
Ordered new master and slave cylinders with accumulator and the soft line from slave. I get a clicky feel from my clutch pedal and that is tied to the master.
If its the clutch fork or PP, then I will place an order with you.
Cheers!
Old 05-08-2020, 02:31 PM
chsu74
chsu74's Avatar
TO bearing tab broke off. Also bearing seal looks to be compromised.
Old 05-08-2020, 03:00 PM
Kevin
Kevin's Avatar
Doesn't look like you have my grease on the ears. What is the condition of your clutch fork pads (contact pad to T/O bearing)? Post a picture of your clutch fork?
How are your needle bearings and nylon fork bushings?
BTW, you have the Sachs Race Engineering 752 pressure plate.
Old 05-08-2020, 06:50 PM
chsu74
chsu74's Avatar
Have not dug into it in detail. Lack of grease is unsettling since these clutch kits come with grease packets.
Old 09-01-2022, 08:26 PM
chsu74
chsu74's Avatar
So its been awhile since the update. I have been driving my 964 and this car has been set aside until I figure how much to dig into it.
The slave cylinder that was replaced with the clutch lasted 600 miles and was defective. I did not find that brake fluid sprayed into the clutch inspection hole ruining the clutch until after replacement.
The decision was to drop the motor and fix an oil leak seeping from cylinder 1. Down the slippery slope we go. Leakdown numbers were great since top end was done 16K miles back. This is a reseal with engine drop labor paid by porsche due to the defective slave..
Old 09-01-2022, 08:32 PM
chsu74
chsu74's Avatar
Going through the motor. Loose bolts found.
SAI wiring disintegrating
One bank was leaking and other bank dry..
Old 09-01-2022, 08:35 PM
chsu74
chsu74's Avatar
New thru bolts and reassembly begins.
Basal Skull (09-04-2022)
Old 09-08-2022, 09:47 AM
Quadcammer
Quadcammer's Avatar
Received 1,406 Likes on 814 Posts
nice man, is it almost done?
Old 09-15-2022, 09:01 PM
chsu74
chsu74's Avatar
A lot of cleaning before assembly. Cleaning cam towers and SAI ports is taking a lot of time at the moment. The motor was never cleaned properly from top end 15K miles ago.
Old 10-24-2022, 10:26 PM
chsu74
chsu74's Avatar
Progress
One side done
Quick Reply: Lost clutch today
