993 Forum 1995-1998
Interior material?
Old Nov 8, 2016 | 11:03 AM
99er's Avatar
99er
Default Interior material?
I recently picked up a 1998 C2s and the interior material is not one I've seen before. It didn't really show in the pictures so I was a bit surprised when I received the car, not that it's bad, just unexpected. I was under the assumption that it was almost always vinyl, or perhaps leather, but wasn't sure what mine is. I'm talking about the area behind the window switches.
Anyone know and was it standard for '98 and was there an associated option code?
Thanks.
File Type: jpg
Old Nov 8, 2016 | 02:20 PM
goofballdeluxe's Avatar
goofballdeluxe
If my memory serves correct, it was a common but unique vinyl trim available on the Carrera S.
Old Nov 8, 2016 | 03:56 PM
MartinC2S's Avatar
MartinC2S
I think it's vinyl too. I have it on my '98 C2S as well.
Old Nov 8, 2016 | 08:26 PM
99er's Avatar
99er
Thanks - so this was a standard thing, just never seen it before.
Old Nov 9, 2016 | 04:04 AM
911PERVY's Avatar
911PERVY
Vinyl is standard, the C2S was quite a low spec car really from factory, gearshift & handbrake worse than standard as an example
Old Nov 9, 2016 | 05:28 AM
Gert's Avatar
Gert
It is called "Texture Leather"
Old Nov 9, 2016 | 09:51 AM
RonCT's Avatar
RonCT
Moderator
It's one of those cool details I found when my car arrived as well. I equate it with "sanded" leather where the bumps are knocked down - very much like a Nubuck sofa I have. It does stand out from the regular molded vinyl pieces...
Nubuck is top-grain cattle leather that has been sanded or buffed on the grain side, or outside, to give a slight nap of short protein fibers, producing a velvet-like surface. It is resistant to wear, and may be white or coloured.
Old Nov 9, 2016 | 10:55 AM
911PERVY's Avatar
911PERVY
Looks like you car is quite heavily optioned then, the door cards may well be leather as they were a special option on the Carrera S in black leather only 99355503120A04
You also have the hi-fi upgrade by the look of it
Old Nov 9, 2016 | 11:31 AM
max911's Avatar
max911
I haven't seen a C2S that didn't have the black pebble grain material on the doors and the dash-regardless of the rest of the interior color.
Old Nov 10, 2016 | 09:30 PM
99er's Avatar
99er
Old Nov 10, 2016 | 09:31 PM
99er's Avatar
99er
any idea what the 5 digit numbers are at the bottom?
