993 Forum 1995-1998
My 993 remote clutch bleed setup
Old 05-07-2016, 09:33 PM
Top-Gun
Top-Gun's Avatar
That's very slick, nice work.
Old 05-07-2016, 10:17 PM
nine9six
nine9six's Avatar
My concern though is what might happen with any mishaps with the bleed screw. Brake fluid coming down onto your engine would make a real mess.
Bruce,
I think we can "what if" most things that we do. Personally, I found Andreas's solution, very elegant...Just like your DYI write-ups and solutions!
Old 05-07-2016, 11:46 PM
SkiDan
SkiDan's Avatar
Andreas,
Great mod that I (and probably others) plan to replicate. Thank you for sharing.
Before I place my order with Pegasus Racing, would you be so kind as to confirm whether these are the correct part numbers/items in the catalogue:
3-36-S-90: 36 inch Size 3 TFE Hose, Straight Female to 90 degree Female
3266-10: 3/8-24 Speed Bleeder Screw, 1.30" overall length
3266-25: 3AN Bulkhead Mount for 3/8-24 Bleeder Screw, Stainless Steel
AN316-6-R: AN316 Jam Nut, 3/8-24 Right Hand
Thanks again
Old 05-08-2016, 10:24 AM
AOW162435
Seared
AOW162435's Avatar
Originally Posted by jscott82
Nice !!!
Entirely your fault, feller!
Thank you.
Originally Posted by nine9six
Bruce,
I strive for elegance.
Originally Posted by SkiDan
Andreas,
Thanks again
Dan,
Those part numbers are good. Rather than a Speed Bleeder, I purchased a regular 3/8-24 bleed screw (3266-01) since I use a Motive pressure bleeder.
Andreas
Old 05-08-2016, 12:34 PM
Jlaa
Jlaa's Avatar
Wow, that is highly impressive ingenuity. Furthermore, you just HAD to include an expansive shot of the claen underside of your auto to rub it in. :-) Question - did you use mild steel for the bracket? I am not an expert at metal work but I wonder if the OCD in you (meant as a big compliment) has given thought to cad plating that bracket ... Or applying some kind of OE-ish corrosion resistance coating to the bracket. The paint is already very lovely .... I am unsure if the factory painted other brackets black as well.
EDIT - I looked at the pics again and realized the bracket was painted black.
Old 05-08-2016, 01:39 PM
nine9six
nine9six's Avatar
Silver, gold or platnum coating in a matte finish would be ELEGANT!
EDIT
I was so enamored with this write up and solution, I forgot to critique...What? Not all metric fittings?!?
Kidding of course
Old 05-08-2016, 02:08 PM
AOW162435
Seared
AOW162435's Avatar
You know what, I may just weld up another bracket and have it done in yellow zinc dichromate. Thank you for the suggestion.
I was so enamored with this write up and solution, I forgot to critique...What? No metric fittings?!?
Kidding of course
The M6 to AN-3 fitting is metric. And I used metric wrenches to assemble the contraption.
Andreas
Old 05-08-2016, 02:17 PM
SkiDan
SkiDan's Avatar
Dan,
Andreas
Appreciate the feedback Andreas. If you ever visit BC's Okanagan Valley, there is a beer here with your name on it!
Old 05-08-2016, 02:42 PM
Foxman
Foxman's Avatar
Thanks for the great write up Andreas. This project is definitely on my list.
Old 05-08-2016, 03:15 PM
OverBoosted28
OverBoosted28's Avatar
Awesome addition to list of Must Do's. Thanks for the info.
Old 05-08-2016, 10:26 PM
kjr914
kjr914's Avatar
^^^ Damn, as if the list wasn't long enough already! This is pure brilliance. I must admit I skipped the clutch bleed a week ago due to how painful it is. I can see a seep on the slave hose connector, so I'm in for it here soon anyways when I change out the hose.
hmm, I"ll poke around for a suitable place to put a bracket on a VarioRam car... Big A, where did you fish that thing through into the engine compartment?
Old 05-08-2016, 11:25 PM
AOW162435
Seared
AOW162435's Avatar
Noted.
Jim,
Your hands will thank you one day.
My pleasure.
Keith,
You are too kind. Pure brilliance to some is shadetree engineering to others.
I found that draping the hose down behind the intake manifold (left side) caused the end to appear in the area where a hose or two enter the engine compartment. Tried it three times and each time I crawled underneath, the 90 degree end was hanging in plain view.
Andreas
Old 05-09-2016, 01:17 AM
OverBoosted28
Andreas, do you know if the parts (previously listed) are good to go, on the turbo? Thanks
Old 05-09-2016, 02:02 AM
AOW162435
Seared
AOW162435's Avatar
The 993 slave & the 993 turbo slave appear very different due the turbo's pressure-assist feature. Do you know if the bleed nipple faces forward or towards the wheel well? If it faces forward I'd say the line & fittings I describe should work just fine. If the nipple faces towards the LR wheel well, you would opt for the 36" line with straight AN-3 fittings on both ends.
Andreas
Old 05-09-2016, 02:17 AM
AOW162435
Seared
AOW162435's Avatar
This is the M6 to AN-3 adapter I used to replace the stock bleed nipple:
Andreas
Quick Reply: My 993 remote clutch bleed setup
