Correct air compressor for 1996 993
Anyone know if the proper compressor is the plastic ribbed cage with or without the emergency light? I read this thread and there are 3 compressors listed but there doesn't seen to be definitive resolution.
https://rennlist.com/forums/993-forum/581085-looking-for-a-993-spare-tire-compressor.html
Thanks - i wanted to enter my car into a concourse this spring and i noticed my car didnt seem to have a compressor. I wanted to make sure I bought the right one. Can anyone else confirm that?
Thanks.
Thanks.
The stock compressor is really of very low quality. I switched mine out with a Harbor Freight special:
http://www.harborfreight.com/12v-100...sor-69284.html
R.I.P
Mine did not come with the emergency light. It worked fine on the occasions that I had to use it. I think that the part that goes in the cigarette lighter broke and I replaced it. It has a place in the garage, somewhere. My first 993 ('95 C2) had the same unit. IF you want a photo I could do that tomorrow. It's to friggen cold to go out tonight.
That was not the one that came with my 1996. I had one of those after my original burnt out, but that one, pictured, burned out even faster than the original.
#10 above -- is a 996 compressor.
I plugged my 993 compressor in just for a trial, when i pulled the plug out all the lighter came with it, its a very tight fit.
So be careful disconnecting it - its a real PITA to get the lighter connected up and back in.
