Porsche 993 Year 1997 34K miles for ~USD48K in Japan
Hi all,
I am considering a Porsche 993 Year 1997 with 34 K miles for ~USD48K.
Below are the service record entries. Please advise if:
- There is a big overhaul needed soon within 1 year, e.g., SAI issue.
- Was there anything expensive fixed in those years.
- Any worrying trend in the service record entries
Thank you for your help!
1997.9.11 - 35 Km: New car inspection
1998.1.7 - 3,455 Km: 3000 Km inspection
2000.8.25 - 14,303 Km: Maintenance, E/g oil, break fluid
2001.9.15 - 19,147 Km: Yearly inspection, E/G oil, wiper plate
2002.9.3 - 23,163 Km: Maintenance, E/G oil, oil F, air (con) F.A/C F, brake fluid
2003.10.11 - 24,614 Km: Yearly inspection, E/g oil, battery, left stop lamp bulb
2004.9.8 - 25,980 Km: Maintenance, E/g oil, brake fluid, power window S/W, rear spoiler
2005.9.28 - 27,766 Km: Yearly inspection, E/g oil, oil F, alternator key B/T
2006.8.30 - 30,155 Km: Maintenance, fan belt, alternator belt, cooler belt, belt sensor, pulley bolt
2007.10.6 - 34,511 Km: Yearly inspection, E/g oil, Left-side marker
2008.4.11 - 35,565 Km: Alternator (re-belt), fan B, g spacer slip, E/g oil top up
2008.9.4 - 37,143 Km: Maintenance, E/g oil, oil F, air (con) F.A/C F, brake fluid, spark plug, fuel F
2009.9.10 - 39,389 Km: Yearly inspection, E/g oil change, tappet cover G/K, ATF, oil pan G/K, drain bolt
2010.8.26 - 42,196 Km: Maintenance, DME relay, battery, R tyre, F padset, evaporator, expansion valve
2011.10.9 - 47,031 Km: Yearly inspection, fan belt chage, alternator belt change, compresssor belt change, power window S/W
2012.8.24 - 50.603 Km: Maintenance: Horn contact plates, F Hood damper, Oil level sensor
2013.9.10 - 53,363 Km: Yearly inspection, E/g oil change, Oil F, F Wiper blades
Seems like typical maintenance / service. SInce you already expect a big overhaul in a year to address SAI issue, that will find anything else "while you are in there". Before you pull that trigger, be sure to search the forum on al the SAI threads, some easy ways to possibly address that short of a top end overhaul.
At this point years more than miles/kilometers is the factor, I suspect it has oil seepage from various gaskets the "while yo are in there" can be addressed.
Service list has little insight to condition of body/paint/glass/interior/etc. Be sure to get a PPI from a good air cooled shop.
Kien_Ersatz,
Thanks for the advice on the SAI issue, the PPI, and info that the maintenance list fixed nothing major!
You are spot on about oil seepage! I noticed oil leaks on the floor after the dealer started the engine, and revved it.
I travelled 6 hours by bus to take a look at the car; the exterior/interior looks fine. I checked for common things listed by you guys and the buying guide here: http://www.jackals-forge.com/lotus/9...buy_guide.html.
I was an Xpat in Tokyo for 1 year and learned a little bit about Japanese when it comes to perfection. They are very very thorough and pay great attention to details. Owning a car in Tokyo is a luxury and unless you have a deep pocket, the parking cost would surpass that of maintenance. I would not hesitate on pulling a trigger if things check out ok. Japanese drives on the opposite side but I haven't seen any porsche with the steering wheel on the right side yet. It's something to consider if you want to bring it back to the states in the future.
This purchase should stop until you find out exactly why it's leaking oil and how much it will cost to fix. If oil dripped onto the floor in just the few minutes when the car was running, you're dealing with a serious oil leak.
If they gave you a price quote for fixing the leak they should tell you what exactly is leaking....my guess is the rear main seal. It's the only thing that justifies a $2K price tag. At $48K, I hope this work is included in the price of the car.
Agree you should find out what is leaking first before you pay up.
