Rear wishbone/lower control arm ball joint replacement?
I tried searching but couldn't find much. Question is, is the ball joint in the rear wishbone (the lower a-arm) replaceable?
I am rebuilding my whole suspension with solid bushings etc. and would hate not to replace the ball joints as well. I know for the front it is easy but for the rear?
I could also get the motorsport wishbones I suppose..
I don't think any of the ball joints in the rear are replaceable. You can get factory cup parts, but I am not sure if those ball joints are replaceable. CUPCAR should know, since he has them on his project car. ERP has adjustable arms with all ball joints, and I think those are serviceable.
You are very serious about your car, and with the effort you are making going all solid, it makes sense to go to Tarrets or the equivalent. As far as the ball joints go, Porsche makes money on each sold replacement part, so why would they bother to make it replaceable? ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Did you see the thread on making your own links? You can buy the helm joints and center parts and make up your own links at significant savings.
https://rennlist.com/forums/993-turb...trol-arms.html
Cheers,
Mike
Cheers,
Mike
RSR track arm is available and the way I'm going, uni-ball on the rear leg, Cupcar bought his last summer
TRW sells rebuilt 993 Track arms for ~ 2/3 the price of new(discounted), you'd need to install your own uni-ball, a friend is currently doing this to his, they press in
There was an out fit in England that was rebuilding them but I can't remember the name
Thanks guys!
Matt is bringing me a lot of suspension goodies mid february. I know the tarett toe links are included and he mentioned ERP also so i'm guessing these arms are included. Have to check with him.
I have a set of suspension arms (all but the toe arms which will be Tarett) coming from partworks.de, based in Germany. I have confirmed with them that they fully rebuild the arms, replacing the ball joints, bushings and A-arm monoballs. I specified sport bushings for all the rubber bushings which is supposed to be the equivalent as RS bushings, and will post once I receive them. They have been very easy to deal with, the only issue is the returning the core suspension units to Germany (the shipping is expensive), but they have a US based agent that will accept them. If you are in Europe it seems to be a no brainer.
This is a much cheaper route than buying new (if you can get the parts), so I will keep you guys posted on how things turn out.
Cheers,
Mike
Cheers,
Mike
SpeedyC2 (02-19-2020)
Cheers,
Mike
Cheers,
Mike
Thanks.
There were Porsche production updates to the arms, and if you replaced with new you also might not have the same part numbers. Good question for them though.
I don't get this- Porsche view them as service items, so they are not re-buildable and are designed to be replaced. As stated they were improved during the production runs. To me this is like tires or brake rotors... why keep the original ones when they are worn? It's not like an engine or gearbox.
