I can't seem to find the specs for front wheel studs. I cross threaded one using my impact wrench by being sloppy...
Can I just pick one up from auto zone?
Not meaning to derail this thread for Falcondriver, but the hubs did not have to be removed so long as you are only going one size up on the studs. There is enough room to get the slightly longer ones in in the back and for fronts there is even more room. If you are just replacing with same size, same answer. Plenty of room to do it.
