proper way to jump start
well, just got done working on the car, have not started the car , about 7 days, got in and nothing, thought about jumping it , had second thoughts, its a porsche, i dont want to burn anything up, ill play it safe and take the battery out get it checked out,is there a trick in jump starting this car?
No, if you have 6 speed, you can also push start.
Never had to on the 993, but one summer, I was having problems with the starter on my SC, I push started it on a daily basis.
assuming you have a Becker factory unit, you will need to enter the 4 digit code after power is removed from the radio. Or, does it not even power up now?
Stewart
When the -ve is grounded there is usually a small spark and if this occurs near the battery it could ignite residual hydrogen gases released from the battery. That would be bad. If you connect on a body ground away from the battery, you minimize the chance of this happening.
Good question! Proper procedure calls for the + lead connected first to the + terminal of the battery. The - lead of the charger should then be connected to a good ground on the car sufficiently away from the battery. The reason being that, if a spark should occur, it will be sufficiently away from the battery to avoid an explosion. Especially important in a Porsche with the fuel tank close by. Any fumes in the "frunk" area could create a bad situation.
I was polishing and spending way too much time primping the car, and left my hood open (not realizing it). So my battery is dead too.
My plan is to jump start this weekend. I would like to add a cigarette lighter style battery drip to her for winter storage.
Can I ask recommedations again?..I know search is my friend but I got so many responses and I know one of you have that perfect model to plug-in.
Many thanks
Many thanks
Many thanks
Many thanks
