993 Forum 1995-1998
Steering Vibration
Old 04-25-2013, 11:56 AM
certz
certz's Avatar
Default Steering Vibration
When I make a left turn I feel a vibration through the steering wheel - kind of like a thumping feel, but not audible. It does not happen when straight or on right turns and starts at about a quarter turn of the wheel to the left. I am going to be under the car this weekend doing other stuff and was wondering if anyone had an idea of what it might be or where to start looking.
Old 04-25-2013, 04:05 PM
1pcarnut
1pcarnut's Avatar
First thought that comes to mind is control arm bushings. At 46k mine were shot.
Old 04-25-2013, 04:25 PM
Quadcammer
Quadcammer's Avatar
Received 1,424 Likes on 824 Posts
wheel bearings?
Old 04-25-2013, 04:32 PM
certz
certz's Avatar
I do not think it is the bushings as I had them done about two years ago. I also had bearings done two years ago but I will check them both with the car in the air.
I am wondering if it is a tie-rod or the rack (I really hope it is not the rack).
Old 04-25-2013, 04:36 PM
relinuca
relinuca's Avatar
Tires...has to be. Steering rack? Not a chance.
relinuca
Old 04-25-2013, 04:57 PM
stace
stace's Avatar
Tie Rod - those are the symptoms I felt when I had a bad tie rod. and I replaced both tie rods; of course an alignment is then required.
Old 04-25-2013, 11:00 PM
rcwelch
rcwelch's Avatar
How old are your tires?...just went through this, looked at everything and then looked at age of tires. Replaced them and no more problem.
Old 04-25-2013, 11:49 PM
certz
certz's Avatar
I do not think it is the tires as I feel the same vibration on my street tires and both sets of track tires (three sets of wheels).
Old 04-26-2013, 12:44 AM
Mike J
Mike J's Avatar
Have you gone under the car and inspected all the moving parts, ie. loose ball joints, bearings, etc?
Old 04-26-2013, 05:38 PM
Beretta
Beretta's Avatar
What tires do you have?
I have Hancook rear tires and thats the worst ever..
Ordered new Michelins!!
Old 08-29-2014, 11:41 PM
hlc
hlc's Avatar
Did you resolve the issue? My 987.2 has same symptoms. Dealer could not find fault with suspension. I plan to rebalance the MSS tires to see if this helps.
Old 08-30-2014, 09:40 AM
fineito
fineito's Avatar
I am no technician, not by any means, but I've noticed at times, when tires go out of balance slightly, that I would sometimes get get a shimmy (thumping feel, as you describe it) in sweeper turns. Then, it would sometimes go away for a bit as the road straightens out. The phenomena would be erratic. Solution? Tire rebalance. I think there is also a chance a steel belt could be damaged, but that has never happened to me.
Old 08-31-2014, 05:19 PM
PRSWILL
PRSWILL's Avatar
I had this happening- wheel was bent on the inside - like I hit a pot hole hard. Had it worked on now is perfect
Old 09-07-2014, 10:41 PM
hlc
hlc's Avatar
Follow up -I had the tires re-balanced and the vibration is now gone.
Old 02-28-2015, 11:58 PM
luckyJ
luckyJ's Avatar
My steering wheel starts vibrating noticeably whenever I past 2:30 on the speedo...I had my bushings changed to elephant racing sports/hardness about 20k miles ago, also tires are Michelin PSS w about 10k miles....
vibration only occurs if I go past 2:30 on the speedo....is this some kind of warning that I'm nearing the car's limit?....anyone have this happen before and what are possible causes please?
thanks in advance...
Quick Reply: Steering Vibration
