Nearly full RS suspension upgrade
With hopefully the last snow the past weekend, it's time to get busy. Mostly rennline and RS parts that I have been collecting all winter. There are plenty of write ups, but I will add some notes here and there. And of course, ask for help
What sway bars are those?
Here is a full parts list
OEM RS parts:
Sway bars front and rear and bushing and drop links
Front uprights
Tie Rods
Rear lower control arms
Rear camber arms
OEM Standard parts:
Front wheel bearings
Front ball joints
Rear KT links
Rennline parts:
Rear toe links
Strut mounts
PSS10 rear spring perch
Solid sub frame mount
Elephant front bushings sport hardness
The car already has RS engine mount, strut bar, flywheel and clutch. My plan is to staying with the standard brakes and get the new 17" Fuchs wheels to keep the corners as light as possible.
OEM RS parts:
Front uprights
Tie Rods
Rear camber arms
OEM Standard parts:
Front ball joints
Rear KT links
Rennline parts:
Rear toe links
Strut mounts
