Iphone App and OBDII
Hi, interested if anyone is using a iPhone App to interface with a bluetooth OBDII.
Which App? Which OBDII? Thoughts and use?
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I bought the GoPoint BT1 bluetooth OBDII reader and I pair it with their free iPhone app. No issues. I leave the 'dongle' installed in my OBDII port 24x7. Kinda fun to monitor the oil temp from start-up through steady state (usually 260F with outside temp at or below 30F).
GoPoint BT1
http://gopointtech.com/products/
DashCommand
http://www.palmerperformance.com/products/dashcommand/
Harry's Lap Timer Pro
http://www.gps-laptimer.de/Home.html
Optrix iPhone mount
http://www.optrix.com/optrix-xd5-overview
How I used it last weekend....
The BT1 is AWESOME! DashCommand is worth every penny, it has a ton of info, will clear CEL's and also does datalogging. If you change a part on the car, you can see if your MAF is reading higher airflow, the IAT is higher/lower, spark advance, etc.. Very useful!!!
Harry's Lap Timer, well, you can see how cool that is! I just purchased a add on GPS antenna that is 5x faster then the iPhone GPS, so there will be even better tracking next time!!
DashCommand
Optrix iPhone mount
TIA
JP
The generic OBD scanners/software can normally only connect to the engine management, and not the other OBD-enabled units in the Porsche 964/993.
As far as I know, there's only a handful of systems that can do all the units in our cars. (Motronic, ABS, air bag, alarm and climate control)
*The Bosch Porsche "hammer" (KTS 301)or later Bosch Porsche tools as PST2, KTS500 or PIWIS
*Freeware Rennlist Scantool Windows software (serial port adapter, as my T-OBD)
*Durametric Windows software with a proper serial cable
*928-diag/PDT999 from jenniskens
Cheers,
Tore
Cheers,
Tore
