Rear air blower
just make the DIY for change the air duct. i found the rear air blower working once i start the engine even i off the heat in ccu. When i off the engine, it stop working.
Which part i should look for it?
Peter,
I'm assuming you mean you changed out the plastic/rubber piece above the cooling fan, right?
Sounds like you are hearing the engine auxillary cooling fan, perhaps? It will run occasionally, most obviously just after you shut down the engine. After a few minutes it will turn on for a short time to help cool the engine when its off. Is this what you are hearing?
Cheers,
Keith
Cheers,
Keith
The rear fan has two purposes, help pushing heated air to the cabin and to cool the engine when no heat is required in the cabin. Details on the operation is explained on my DIY website: www.porschehvac.bergvill.com
Cheers,
Tore
Cheers,
Tore
the problem is when i insert the key and make 1 or 2 turn ( the engine not fire) and the engine is still cool , also i push ccu air circulation button on position , the rear fan is still working.
Maybe you have a defective rear duct temperature sensor. This is the one that makes the CCU able to control the cooling function of the rear fan. You could use a Porsche OBD tool to check the sensor value.
The rear fan shall run at low speed (40-45degC) and high(62-57degC) when ignition is ON and mixer valves are closed. (minimum heat setting) At igntion OFF, the fan run in low speed if the air duct temperature is above 75degC, and shall stop when below 70degC.
Cheers,
Tore
Cheers,
Tore
