993 Forum 1995-1998
Spoiler Alert!
Old Nov 16, 2012 | 12:56 AM
ilko's Avatar
ilko
Agent Orange
Exclamation Spoiler Alert!
Something odd happened tonight... I drove the car for about half an hour at various speeds up to 60MPH, then stopped but did not turn it off. When I stepped out I noticed that my rear spoiler was fully erect! Well, technically it was fully horizontal but anyway...
I closed it with the switch inside the cabin and then drove off. I drove for another 1.5 hours at speeds well above 55MPH, but the spoiler didn't go up. I also am not getting any ! messages on the dash. The spoiler light comes on when I start the car and comes off after I drive off.
Any insight as to what the issue could be? The car is a '96 with the stock spoiler module. New spoiler wall a year ago.
Old Nov 16, 2012 | 01:17 AM
nile13's Avatar
nile13
Ilko, is the speedometer working properly? Also, try your cruise control and see if it engages on the next drive. Could be clutch or brake switch among other things.
Old Nov 16, 2012 | 01:19 AM
ilko's Avatar
ilko
Agent Orange
Thanks Mike. Speedometer's working fine. I don't even know how to operate the cruise control. Never ever used it. But will try it. Clutch was replaced over the winter, new components all around. Brake switch activates the brakes fine as well...
BTW I picked up your cupholder tonight, will drop it in the mail tomorrow.
Old Nov 16, 2012 | 07:49 AM
95_993's Avatar
95_993
ilko,
I think there may be a relay (like 964). Points on the rely may be sticking.
Old Nov 16, 2012 | 09:00 AM
ilko's Avatar
ilko
Agent Orange
I'll look into that, thanks!
Old Nov 16, 2012 | 11:58 AM
JM993's Avatar
JM993
Check whether the micro switches in the spoiler transmission are functioning with a continuity test.
Old Nov 16, 2012 | 12:02 PM
HiWind's Avatar
HiWind
Any of your Viagra missing?
Old Nov 16, 2012 | 12:31 PM
DocTock993's Avatar
DocTock993
If you have not done it, check to make certain the jumper/connection under dash on passenger side is not partially disconnected.
Old Nov 16, 2012 | 12:58 PM
boman993's Avatar
boman993
This seems to be common! I had trouble reconnecting mine after my speed
function disabling mod. The connection appeared to be tight, but it wasn't
solid. I was advised by a fellow RL'er to try using 2 zip-ties to really snap/force
the plug and module together. It solved my spoiler woes in the spring.
Old Nov 16, 2012 | 01:36 PM
ilko's Avatar
ilko
Agent Orange
Cool, thanks for the tips guys! I'll investigate further...
Old Nov 16, 2012 | 02:56 PM
epj993's Avatar
epj993
I've had those little rubber nut covers on the left side under the spoiler come off, usually after washing & drying. They tend to fall into the plastic spoiler gear cover and jam one of the micro switches.
Old Nov 16, 2012 | 03:31 PM
JPS's Avatar
JPS
<Begin teen humor>
I hate it when my nut covers come off after washing and drying
<end humor>
Old Nov 16, 2012 | 03:36 PM
ilko's Avatar
ilko
Agent Orange
Beats pinching my nuts by a country mile
Old Nov 17, 2012 | 01:51 AM
Stealth 993's Avatar
Stealth 993
Is the relay clicking when you get to speed and slow down? I can hear mine.
You might just get lucky and unplug, check contacts, then plug back in.
Mine stopped one time, after my 2yo daughter helped me clean the car, she unplugged part of it.
Old Nov 17, 2012 | 01:56 AM
CalvinC4S's Avatar
CalvinC4S
I can lend you a spare control unit to test with if you need to.
