How do I test fresh air flap servo motor?
So I pulled the fresh air flap servo motor from my 993 as it stopped working (does not move) and throws a code 24 - "fresh air flap motor" with my PST-2. The potentiometer tracks and whiskers do not appear to be noticeably burned, nor to any solder joints appear to be broken. (See pic)
My question is, before I spent $300 on a new unit, how can I test and possibly repair my servo motor? Which pins (#1 thru #5) do I connect to a 12V source to test this unit? Which cold solder joints can be the culprits and how do I test for their continuity?
Marc G.
Marc G.
The electric motor could be faulty, there has been reports of motor wear and short circuit.
Below is a schematic of the servo, you could connect 12V to terminal 4 and 5 to test the motor and limit switch, and a ohmmeter to terminal 1 and 2 to test the pot.
The Climate Control Unit servo output could be shot, I would guess the easiest way to test this is to connect the servo to another servo output and test it in-car. A CCU failure is by the way fully repairable.
Cheers,
Tore
Cheers,
Tore
Okay guys. It helps to have a PST-2 to diagnose these things. (I set up a clone one from a IBM Thinkpad this year. Not too difficult to do.)
Here's what I did ...
Like Tore says posts #4 and #5 are the voltage sources to drive this servo. I noticed (with multimeter) that they switch between +12V and -12V, depending on the direction desired. Also, the potentiometer is read by the system so that it knows the motors exact position at all times. I even tried to fool the system by disconnecting and reconnecting the motor after I manually moved the arm (by taking box apart temporarily. Don't worry, I didn't strip any gears.)
My servo motor appears to be dead, dead, dead. And, once again, no significant burn marks on the PCB. So I took the motor out of the defroster servo and put it in the fresh-air servo and it works perfectly! When I put the "bad" motor into the defroster servo, nothing. So I guess my electric motor is bad.
I know some folks had some bad servos due to a shorted out board. Anyone willing to send me the supposed good motor to replace mine? What Porsche wants for a new servo is quite a bit.
Marc G.
Marc G.
I'd like to request a PM as well. TIA
I went through this on my C4. I propped the servo up under the hood so you can see it from the drivers seat and plugged it in. The started the car, and moved the HVAC dial to activate the servo. They move slowly.
I purchased another used servo as a backup, just in case. So I think I've fixed the problem, at least temporarily.
Marc G.
