BEST OIL
OK Guys,Try not to beat me up too much. I know oil discussions are always bad to bring up. My question: I have used AMSOIL with great results in cars and my Harley.Considering using it in my 993. Anyone using this or any comments as to good or bad would be appreciated. Thanks, MACK
Is there a reason to change the oil which has been used to date in the car? My reading before I got mine indicated that changing the oil that has historically been used in the car can be problematic with seals.
Hi Mack,
Nice car!!
Answering the title of your post, IMHO the very best oil one can buy is Motul 300V, however its NOT cheap.
I've never disassembled and inspected an engine after using Amsoil so I cannot offer anything constructive. For me, that's the definitive prerequisite for any lubricant.
Mobil 1 V-Twin oil isn't bad either,...
Nice car!!
Exactly. On lap 12 at the moment. Gotta leave for a porsche event in an hour so trying to get it all in before we go.
https://rennlist.com/forums/993-foru...ml#post9898711
Lots of opinions on oil. Maybe because no one has ever had an engine failure that they can directly attribute to particular oil. My two cents on the issue is to not use a too high a viscosity oil as the very soft seals on the lifter cartridges on these older cars can be forced off from the higher cold starting pressures and all the attendant clacking that will follow at each future startup. Some of the modern oils such certain Mobil 1 grades have higher scuff reducing additives and may have some value in preserving the valve train.
Andy
Andy
I am a huge fan of Brad-Penn, however the original question was posed about what is THE best oil without any qualifications so I simply stated my opinion,...
For non-synthetics, Brad-Penn is at the very top of my list and for synthetics, 300V tops them all.
Knowing that most folks may not be willing to spring for 300V, I thought I'd offer a reasonable synthetic alternative thats well-proven.
Any of these products will protect these engines VERY well provided they are changed regularly to flush the engine of the byproducts of combustion.
JMHO,..I do not wish to trigger any oil "wars".
No war for me either guys. I am just wondering if anyone has used AMSOIL IN A 993 AND WHAT THEIR RESULTS WERE? As I said, I am a believer and use it in my Harley and other cars. Just want to know the opinion of others on it before I go from Mobil 01 to the Amsoil.
You always get this argument "I have used oil XXX and am very satisfied and it gave great results" . What exaclty does that mean?
We can get indicators of how good an engine oil is by:
IMHO, the only way to really find out if one oil is better than the other is to run two identical engines side by side, in exactly the same conditions for quite a while, take them apart and measure if there are any differences. I am willing to take the oil analysis as a proxy for this, with the assumption of less wear metals, "better" oil. However, just gut feel, or seat of the pants dyno'ing, or just its expensive so it must be good does not really cut it for me.
You can select a "good" oil by its characteristics (Zinc levels, heat tolerance, viscosity range, processing, etc) but you really do not know until its really used and measured in a controlled environment.
Just my two cents...
Cheers
Mike
- Runing an oil analysis on several changes over time to see trends. To be statistically significant, we need sample sizes more than 1 car, several changes, and control cases using other oils.
- Tracking oil consumption and seeing if it gets better or worse. If it gets better, the oil is usually tagged as "good" (which may not be really true from a wear perspective)
- Tracking oil leaks and puff of smoke on startup/running and see if they get better (oh yeah, see above)
Cheers
Mike
I prefer Rice Oil for the high smoke point, with a little bit of chili oil for some kick
I use Rotella T6 in my Porsche and my TDI Jetta. No UOA's but the people at BobIsTheOilGuy.com speak very highly of it for almost every application.
