993 Forum 1995-1998
horn going nuts!
Old Oct 5, 2012 | 12:36 PM
stairmasterman911's Avatar
stairmasterman911
Default horn going nuts!
so out of nowhere my horn starts going off yesterday. sort of a staccato crazy nonsensical thing. didn't do it this morning though. this happened to me one time on a toyota when the battery was going dead. any thoughts?
Old Oct 5, 2012 | 12:50 PM
177mph's Avatar
177mph
Whats was happening when the horn sounded? Were you driving it - or was it simply parked? Parked - likely a alarm problem I would think. Driving - it could be the bushings in the horn ring - a common issue.
Old Oct 5, 2012 | 01:38 PM
swmic's Avatar
swmic
Probably the rubber grommets holding the horn button away from the contacts. In your case, they have probably failed. Do a search on the topic, it's a common problem. There are several fixes you can do.
Old Oct 27, 2012 | 11:36 PM
shellback's Avatar
shellback
Is this the part required to fix the problem?
http://www.ecstuning.com/Porsche-199...eel/ES1477044/
Old Oct 28, 2012 | 12:35 AM
Marco8's Avatar
Marco8
http://www.ecstuning.com/Porsche-199...eel/ES1477044/ .
[IMG]http://i1093.photobucket.com/albums/i433/E36Partsforsale/326152_x600.j
pg[/IMG]
yes, that looks to be the replacement part
Old Oct 28, 2012 | 09:35 AM
shellback's Avatar
shellback
Thanks Marco.
Old Oct 28, 2012 | 04:29 PM
justin993's Avatar
justin993
temporary fix is to fold up a business card and insert on top between wheel and airbag cover. Do one on the bottom if necessary
Old Oct 28, 2012 | 06:30 PM
pirahna's Avatar
pirahna
That's my fix for now, a permanent fix is down on my list of projects.
Old Oct 29, 2012 | 04:24 AM
ToreB's Avatar
ToreB
Here's several tips on this:
https://rennlist.com/forums/993-foru...-for-help.html
Cheers,
Tore
