CEL and flywheel -- is this urgent?
Recently the CEL has been lighting up fairly often in my car and the fault codes always read as a misfire -- sometimes it's all cylinders, sometimes it's just 3 or 4.
I have read a lot in the archived posts which discuss the misfire codes actually being caused by the flywheel. I also have the main symptom of a bad flywheel that I have seen posted -- the engine chatters/wobbles when it is turned off (are there any other symptoms to be looking for?).
I have started working through the main ignition parts; I have replaced the spark plugs and will be changing the distributor caps next, but I have a feeling that the main issue will end up being the flywheel.
My question is: if the flywheel is the problem, how urgent is it to change it? Could you cause damage by postponing this fix? Once it is replaced, will the engine feel smoother?
Any advice or experience with the matter is greatly appreciated.
The car has approx. 54K miles.
If its the flywheel it should be good for quite a while - the inside piece is rattling/loose and is causing the crankshaft to slightly vary in speed, which the computer picks up as a misfire. Its not going to fly apart, and if you are getting a good rattle when you shut it off, that is definitely evidence.
You have done the usual stuff, like making sure that your belts are truly Porsche OEM?
Does the car feel smooth or is it a bit rough on idle, etc?
Cheers,
Mike
Cheers,
Mike
RL Technical Advisor
Thank you for the responses.
The idle is smooth when I first start the car, but after the engine gets hot (particularly after stop and go driving), the idle is far less smooth -- the engine feels almost "lumpy".
From what belts I can easily see, they all appear to be OEM belts.
I think I will be headed to the spark plug wires after the distributor caps. By the way, what is the recommended service life for the spark plug wires? While changing the plugs, I did not notice any cracked wires, but they were certainly starting to show their age.
The most common time to notice bad plug wires is starting the car when the weather is extreemly damp/wet as this is when the voltage in the bad wire will jump to the surrounding metal (sometimes you can even see it).
Plug wires aren't difficult, just "challenging". If doing the job with the engine in the car it helps to have long, skinny arms (an extra elbow joint would help too).
you can save some money by purchasing the wire kits and re-using the connectors, assuming they are still good.
new full 993 wire set isn't cheap.
Cheers,
Mike
Cheers,
Mike
