Truth about 2S
#122
Moderator and 993 whisperer
You callin' me a sucker? Huh? Lol. No... really...if you are, it's fine. I's just a word. So if so, why? I rarely go for games - this guy seems like he really does want to come around.
#124
Thank you Michael. Apology accepted.
No need for me or you to say anymore about it as I think that takes care of us mending 'our' fence this time.
As for the doubters, I'd like to think he meant it and I do feel he was sincere..... I may be wrong, and only time will tell, but I feel that Bonne and I are both right this time. I don't think he'll be apologizing to us again.
#125
#126
#128
Lol, John. I should go chase the AC problem in my car, actually, since you mentioned car repair. And yuck - radiator hoses (!) in the truck. And the Miata is probably due for an oil change. If you get bored, come on down and help.
#130
The May issue of GTPorsche has a nice article compairing the 993 C2S and C4S. Nothing earth shattering but it always nice to read current articles about the cars we love and drive.
#131
To achieve turbo like suspension on either model requires the optional M030 (sport chassis) to be fitted and even then you don't get the rear springs or rear anti-roll bar of a turbo model.
The brakes of the C4S are not lifted directly from the turbo model but rather follow the form of the four wheel-drive models with their hydraulic brake servo system as opposed to the 2 wheel drive models Vacuum servo. The discs and callipers / pads are taken from the turbo model, the rest is C4 with a further reduction in rear switch-over pressure from the C4's 45 bar to 40 bar for the C4S, the turbo is 55 bar and oddly enough the standard 2 wheel-drive models are 40 bar all with a reduction factor of .46 . The brakes feel more powerful because the pedal pressure is multiplied by a factor of 4.8:1 on all four wheel-drive variants and only 3.15:1 on two wheel-drive ones.
The RS model shares the C4 hydraulic system but with a reduction in pressure multiplication to a figure of 3.6:1, so evidently the development driver found the four wheel drive settings to be "over servoed".
I believe the "more planted" "less floaty" feel of the C4S model is directly attributed to the extra weight of the car and its extras and four wheel-drive hardware balancing the weight out more evenly between front and rear. I am sure all owners would agree a full tank of fuel and tyres with a generous tread depth soften the ride of our cars noticeably.
To say that the Carrera S interior is "bog standard" is not quite true. The dashboard and door panels are not covered in plastic, but in a mixture of “leatherette” and real leather with a brushed effect only found on the S model.
#132
Nice to see the technical accuracy in the above. But this isn't 1997. In 2012 (hell, 2002), all but the museum piece cars have been altered. Some for the better, many not..........
As far as the brakes go, in the 35 years I've been paying attention to cars, conventional wisdom over here pretty much considers same-for-same on the hardware. And 99+% of the time that will mean calipers and rotors. Sometimes differences in the master cylinder. With a (US delivered) RWD v. AWD 993, you do have the complication of vacuum v. hydraulic assist to compare/contrast. But when you start getting into pressure limiters, I think you lose most everyone.
And I must be the outlier, as I've never noticed differences in fuel level or tread depth, and hardly even weight until you get to GVW maximum, as making a difference in ride quality. At least here on the third world goat trails we call roads in Northern California. Then again,Ilately 'm finding a solid bushing, large torsion bar, race shell equipped Targa on 17" wheels surprisingly passable comfort-wise.
