993 Forum 1995-1998
Dual distributor rebuilder?
Old Apr 4, 2012 | 11:10 AM
mmasse's Avatar
mmasse
Default Dual distributor rebuilder?
I will have the engine out for a top-end rebuild and would like to take advantage to have the distributor rebuilt. I will not like to spend the time doing it myself (too many projects at the same time...too little time) so I am looking for a shop to send it to.
Can you recommend a shop? ideally on the east coast. Any idea of how much will this cost (this could potentially change my mind!!)
Old Apr 4, 2012 | 01:08 PM
solomonschris's Avatar
solomonschris
Steve Weiner - Rennsport Systems, Portland, Oregon. He rebuilt the distributors on my last two 993 NA's. I believe he is the only one has the OEM bearings, in the event you should need them. How many miles on you car that needs a top end? Was it valve guides?
Old Apr 4, 2012 | 01:36 PM
geolab's Avatar
geolab
Old Apr 4, 2012 | 02:49 PM
axl911's Avatar
axl911
+993 for Steve Weiner. He rebuilt my 964.
On my 993, I have the skill and did it myself. But if I was to send it in, it would be Steve W.
Old Apr 4, 2012 | 02:50 PM
CHRIS WU's Avatar
CHRIS WU
Should I worry about my?it's not the mailage I am worry about(16000 miles), but the age of the car (1997C2S)??
Old Apr 4, 2012 | 05:09 PM
IXLR8's Avatar
IXLR8
Well the distributor drive belt will run you $7.25 and the drive pin for the gear, under $3.82 for a whopping total of about $11.
Whatever the charge for the rebuild is, the balance will be labor. I rebuilt the distributor myself...an easy DIY.
Old Apr 4, 2012 | 05:49 PM
Mike J's Avatar
Mike J
Yeah, you can DIY in less time that it takes to box it up and sent id out, and then receive the package.... :-) - its about an hours work. I have also a shortened procedure, you do not have to remove the secondary dust cover nor shaft. If the bearings are good, its pretty quick.
If the bearings are bad, there is a potential source for bearings at hopefully a reasonable price that we are waiting on.
Cheers,
Mike
Old Apr 4, 2012 | 10:43 PM
WBYonder's Avatar
WBYonder
...plus 3.64 for the distributor o-ring, if you choose.
Old Apr 4, 2012 | 11:17 PM
MarkD's Avatar
MarkD
the bearings are the question
If needed, of course
I also hear there is a new business in the works right here on Rennlist
You are being modest, Alex
Quite unlike you
Personally, I would go with Steve and his experience
Old Apr 5, 2012 | 01:44 AM
WBYonder's Avatar
WBYonder
Oh, and to the OP, GO HUSKIES, BEAT GARNETS!!
(Just had to say that, even tho' we haven't done too well the past few years!)
Old Apr 5, 2012 | 05:59 PM
AOW162435's Avatar
AOW162435
Seared
Another option: https://rennlist.com/forums/6391180-post12.html
Andreas
Old Apr 5, 2012 | 06:48 PM
IXLR8's Avatar
IXLR8
Unfortunately Mark, as most of us know, the bearings aren't available from Porsche, Bosch or the aftermarket at all, and if they are, not at what I consider a reasonable price. If they were, I wouldn't bother modifying a standard 7201.
BTW, a business not making any money is hardly a business.
Old Apr 5, 2012 | 06:57 PM
MarkD's Avatar
MarkD
I'm no Leonhard Euler but I can do basic math.
