993 Forum 1995-1998
Notes from a Pedal Assembly Rebuild
Old 10-31-2023, 08:45 PM
  #46
mferris
mferris's Avatar
Yes - outside the Heim joint, that’s what I did. I reinstalled everything and while not as pretty and clean as yours - I believe the new clutch kinematic lever fixed my clutch release challenges.
Old 10-31-2023, 08:52 PM
  #47
IXLR8
IXLR8's Avatar
When ever you have a retaining clip or a cotter pin on a shaft, you always place a flat washer under it.
Old 10-31-2023, 09:30 PM
  #48
Foxman
Foxman's Avatar
That brake push pedal had fused onto the shaft in my 964. I spent several nights in my garage cursing the moon. Finally had to remove the front wheel, disconnect the push pedal from the other side, and pulled the whole assembly out, push pedal and all. I used a puller to get the push rod off the shaft, and the damn monoball popped off and stayed glued to the shaft. We had to cut the monoball to get it off, what a Nightmare.
Old 11-01-2023, 08:53 AM
  #49
mferris
mferris's Avatar
I’m continually fooling myself that I actually like doing these projects. Rust, though, is where I draw the line.
Old 11-01-2023, 02:04 PM
  #50
Foxman
Foxman's Avatar
Good advice, and rust never sleeps.
Quick Reply: Notes from a Pedal Assembly Rebuild
