These are neat "jack" stands!
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Ps. You also have safety chocks preventing car rolling of 4 poster?
As for those ESCO stands, they need to get someone who knows how to weld. Those are terrible looking welds.
Jackpoint jackstand. Too bad its not height adjustable. But I could see how it could still be useful.
Each of the designs has a use for sure, and there is certainly no universal stand that does it all. I just thought the idea of automatically "indexing" when the car is being lifted is a great idea - and none of the examples I have seen here does that.
Before I got my lift, I used jackstands for years, and no matter the design, they are a pain in the *** to get in. Its a bit better when you use the engine as a jacking point, so at least you can get in the rear stands with clear jack points. Jacking the front was a total pain.
And I agree, the ESCO stand welds look like they were done in a rush, you can almost see the splatter.
Cheers,
Mike
They TIG welded up 30 thou stainless steel in a T joint. The fillet was seamless with no breaks taken and it looked like someone ran their finger along a thin bead of putty. Good penetration and the proof in the joint will then be verified in a lab.
Cripes, I can gas weld far better than those ESCO welds.
http://www.harborfreight.com/automot...nds-34924.html
I have the 6 ton models, 24" lift height and solid as a rock. It does take a while to get the car up in the air but once there its plenty stable to run the engine. My car was doing 100mph in 6th the other night on these. (back wheels off)
PS - RL'ers get them for less $
The 'under-tire' jackstands wouldn't seem to make much sense for a C2 - can't stop the front wheels from spinning freely, and you're generally removing the rear wheels to do your work. Normal jackstands in front keep the car from rolling around, succumbing to gravity and falling on your noggin.
I can't deny they're expensive. They are made 1-at-a-time in Illinois. I refused to off shore them for a 30% price reduction - even though that gets them close to the Esco price. They can't be adjusted, but used in pairs you get lots of space under the 911. User comments - folks really like the stability. They were design with the track in mind - one place you can't use your lift. BTW - I owned a lift for 3 years before I invented them. I still use both in my own garage.
