Latest DIY on removing bumperettes?
I found various articles but would be great to hear how to best remove he bumperettes and how to fill the holes so it can all be painted and having the clean look.,
I noticed many cars where only the fronts were done but not the rear...any particular reason for this?
Do a search on the front bumperette removal. There are many discussions and how to's. For most people it's remove the bumper cover and off to the body shop with it. It can be done on the car, but the risk of having the car at the body shop is not worth it. Besides, there are other maintenance items that can be done with the bumper cover off.
Many 993 owners do the conversion to the turbo front bumper cover (no bumperettes) at this point and sell their original bumper cover.
The rear is the same drill.... remove the bumper cover and off to the body shop. That's what I did. It is a very clean look. There are two aluminum supports for the rear bumperettes that have to be removed - very easy with a Dremel grinder.
Trying to decide if i will fix the holes myself or let the bodyshop do it
You have the turbo bumper which is great. Just pull it off and take it to the body shop. Same for the rear if you want the look cleaned up. I assumed you had a narrow body. Unless you have automotive painting skills, I would sub it out. They can fill the license plate holes at the same time.
An alternative is to color match the bumperettes which is what I did. Bought an extra set so I could always put it back to stock. Plus you get to retain some of the protection they offer.
I filled mine with the recommended filler and it worked out OK. If I were to do it over again, I'd find a plastic bumper cover repair place and have them "weld" in a filler piece of polyurethane bumper material, then use the filler. Simpler, faster and probably better.
Thanks - in europe they dont have them at all so i figured i will do the same. Other cars with painted bumpers don't have those silly things either
hb:
I had my car's front bumper done by a local high end body shop, and the proprietor told me the only proper way to fill the gaps is to weld in plastic. He cut the pieces from an old Porsche bumper.
I don't mind the rear bumperettes, and have left them on. They don't interrupt the flow of the body lines like the front bumperettes do.
Mike, that painted grill looks great btw. I think Porsche should have done this from the start.
