Cold air comes in thru door handle, normal?
This morning I went for a drive on 30 degree weather, and I noticed that a healthy stream of cold air manages to make it through the door handles inside the car. This is the case on both doors. Is this normal?
I've noticed this - but only when the sunroof is open. I assume that creates a pressure differential and the easiest path in is via the internal door pulls. I've also noticed it on other (non-911) cars so it did not bother me...
Yup, I sure did have the sunroof open. Hmmm interesting.
It could be this:
![](http://i5.pixs.ru/storage/6/6/9/feltpiece1_8174475_3561669.jpg)
Greetz.
~ The Eagle ~
'96 Polar Silver/Black C4S, manual, litronics, LED's in the positioning lights, alu/leather shifter & handbrake,
silver face gauges with alu rings, sport seats, full leather interior, motor sound airbox, stainless door sills,
valve caps Porsche crested brushed alloy, front protection bar, with split rear grill and layered with Meguiar's NXT Tech Wax
'92 Carrera 2 (Sold)
'89 Carrera 3.2 (Sold)
Meh, did the felt, didn't do much.
I stuffed a blue shop towel in the area where the rod comes through the panel, seems to do the job for the most part.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
the felt will cure it, someone just did the mod on a UK forum
http://www.911uk.com/viewtopic.php?t=68973
This is a feature that comes with the car, it helps with the circulation. it was designed in the windtunnel by the Porsche engineers in order to on-up their competition.
Or its just a screw up.
I tried the felt, it did not seem to work, but perhaps I was not doing it correctly.
You should try this in a Targa, with that big roof open, the damn wind almost whistles out the door panel..
Cheers,
Mike
PS the TSB for this, along with all the others, is on pcarworkshop.
Cheers,
Mike
