Anybody have the alternator shaft tool?
97 993. Changing the belts and looking for the tool that holds the alternator shaft in place (part number 999 571 052 02). Anybody in Socal have one I can borrow?
Thanks,
Nick
Thanks,
Nick
King of Cool
It's something you should keep it in your tool kit in any case so it's better to just buy one.
Pelican has it for $30, I don't remember where I bought mine but it was about that price.
Oh, and if Ray Calvo was still with us, there would be a reply with "cheapskate!" somewhere in the post...
OK OK. Yes cheap over here. I was hoping to get one quickly as I broke a belt today (the dealer wants too much $$). In the toolkit?? Sears huh? I will look for it. And after I buy it, anyone can borrow it!
Flying Finn, do you indeed fly? I am a pilot too - GV currently.
NGH
NGH
Not that I endorse cheap tools but...
If you have an O'reilly Auto Parts, they had a cheap set of triple squares when I needed one for the old pressure plate bolts.
http://www.oreillyauto.com/site/c/de...%21star+socket
$4.99 for the set and it worked for what I needed (not suggested for everyday use but it worked and no other store stocked triple squares in my area)
Then you can buy the Blue-point socket adapter for future use.
Good Luck with it.
Good Luck with it.
Good Luck with it.
Good Luck with it.
They are called XZN or Triple Square.
Go ahead and get the auto store one pictured above, but then get a VIM or Blue Point or preferably Hazet short 3/8" drive socket. Make sure it's short!
King of Cool
NGH
NGH
It's not really being cheap but as you've noticed, when you break a belt, you need one and it can happen on the road... Ask me how I know (I have one but it wasn't in my tool kit when I broke a belt...)
I don't fly, at least with a plane, my nickname comes from old hobby of mine, below is my old avatar.
The Blue Point brand mentioned is Snap-On. You need the 10mm size.
http://buy1.snapon.com/catalog/item....e=&dir=catalog
$7.60 for the single, but high quality triple square, which is short enough to work with a ratchet. If you order one, just order 2...one for the tool box and put the 2nd in the tool kit in the car. The Porsche tool is crap. I bought a new one to put in the tool kit and it was battered after using it once. I wish I'd bought a 2nd snapon...
As others mentioned, these are quickly procured from the local auto parts store as well. The ones I've seen might have to be cut short or used with a closed end wrench instead of a ratchet.
Hi Nick
I keep these and a 10mm ring spanner and a small bit of pipe for leverage in the trunk, small light and cheap and do the job well
http://www.ebay.co.uk/itm/SPLINE-BIT...#ht_584wt_1021
Ash
Ash
