A/C and Revving Issues
07-04-2011, 01:39 AM
Noodle Jr.Rennlist Member
Been driving the Cactuswagen a lot here lately and have some minor issues. First one is the revs jump up pretty high at startup but not all the time. Then when I restart after it is warmed up the revs kind of get stuck for a second or two before settling to idle. Second question is when the A/C is on should the fan in the front (drivers side) be on constantly or cycling on and off? And the ISV is clean BTW.
07-04-2011, 01:52 AM
AddictRennlist Member
Fan should be either on high or low. If it cycles every 10-20 seconds it's a sure sign of dead resistor.
07-04-2011, 09:12 AM
SearedRennlist Member
You should clean the ISV.
Andreas
07-04-2011, 09:18 AM
Yeah. Check the ISV and make sure it's clean
07-04-2011, 11:13 AM
Quote:
Originally Posted by
nile13
Exactly what it is doing. So that fan should run constantly with the A/C on?
07-04-2011, 11:21 AM
Cactus
I think mine does.
Andreas
07-04-2011, 12:34 PM
My fan runs all the time even with the car off. Is that wrong?
Mike
07-04-2011, 12:37 PM
Arena993
Mike
That's a sure sign that your ISV is slightly out of phase. You should clean it.
Andreas
07-04-2011, 12:48 PM
I'd recheck the ISV and clean again!
Andy
07-04-2011, 12:50 PM
Yup, I'd say clean the ISV, an out of phase ISV will cause problems.
07-04-2011, 01:00 PM
I cleaned the hell out of the ISV months ago. Do I really need to clean it every month?
07-04-2011, 01:11 PM
I'm not sure if anyone mentioned it yet, but the issue may be with your ISV.
Just a thought.
Andreas
07-04-2011, 01:23 PM
By chance did you check the ISV to see if it was clean?
07-04-2011, 01:24 PM
AddictLifetime Rennlist Member
Someone may have mentioned this already, but it could be a dirty ISV.
07-04-2011, 01:37 PM
Seems like you guys are suggesting it is the ISV.....
