993 Forum 1995-1998
My 8mm socket fell into the crankshaft pulley area
Old 06-18-2011, 09:10 PM
911Dave
911Dave's Avatar
Default My 8mm socket fell into the crankshaft pulley area
Is there a way to find this and fish it out? While I was replacing my distributor caps, I ended up dropping an 8mm socket and I'm 99% sure it wound up underneath the pulleys at the crankshaft, although I can't see it. If it is indeed there, what's the best way to get it out? I tried a magnetic screwdriver, but I can't get the tip close enough to attract it.
I took the plastic engine tray off but nothing fell out. Can the area be accessed from underneath somehow? If anyone's got any wisdom to share, I'd appreciate it.
Old 06-18-2011, 09:21 PM
Silver993
Silver993's Avatar
a "magnet on a stick" is a must have for working on a 911. Do yourself a favor and run out and get one before going any further. Mine is a magnet on an telescoping rod. These can be found in most automotive departments. They're real headache preventers.
Old 06-18-2011, 09:24 PM
Dudley
Dudley's Avatar
I bet most 993 owners have done the same. Fishing with a small permanet magnet will work, eventually.
Old 06-18-2011, 09:58 PM
ble2011
ble2011's Avatar
I have a tool that has a long flexable shaft with a magnet on the end. You can bend it around obstacles and works great for these types of problems.
Old 06-18-2011, 10:04 PM
FlatSix911
FlatSix911's Avatar
This may be the most important tool in tool your tool box
Old 06-18-2011, 10:10 PM
axl911
axl911's Avatar
Been there. Done that many times. Take a small but strong magnet and tape it securely to a piece of coat hanger. Bend the coat hanger to a curve because that is the only way it will go into that area.
Go fishing...but don't lose the magnet in that area!!!
Old 06-18-2011, 10:29 PM
Slow Guy
Slow Guy's Avatar
I have at least 2 magnet pickups that I've had for over 25 yrs. Used them many times.
I have a newer Kobalt telescoping magnet with a LED light on the magnet end too. It works well as long as you don't have to get through real tiny spots.
As someone else has already said a magnet pickup is a requirement for working on a Porsche.
Old 06-18-2011, 11:28 PM
TMc993
TMc993's Avatar
While you're at it, purchase a similar telescoping rod with a small mirror mounted on the end. It will help you locate the piece you drop so you can get the magnet on it.
Old 06-18-2011, 11:50 PM
Mike J
Mike J's Avatar
I like the flexible shaft with a magnet on the end the best. Also some remote pickup pincers, and mirrors. i also go a bit high tech at times, I also have a wireless boro-scope that is quite useful for looking for fallen parts.
I also have the telescoping straight shaft type of magnets, but with all the nooks and crannies of the 993, it often is not able to go around the corners.
Cheers,
Mike
Old 06-19-2011, 12:46 AM
911Dave
911Dave's Avatar
Well! Not much question about what I need then. I've been wrenching Porsches for 7 years but I've been lucky enough to not need one until now. I'm off to Sears tomorrow for a couple other tools, so I'll throw a magnetic picker-upper in my cart too.
I do have a telescoping mirror and that's been very helpful at times. Unfortunately there's not enough room to maneuver the mirror down there.
Thanks for all the help!
Old 06-19-2011, 12:59 AM
Mike J
Mike J's Avatar
Wow, 7 years! You must have stickier fingers than I! :-)
Old 06-19-2011, 09:07 AM
swmic
swmic's Avatar
BTDT. Working on these things really tests your patients at times. I think I used a bent coat hanger to move it out and a magnetic stick to pull it out. Good luck!
Old 06-19-2011, 09:33 AM
No HTwo O
No HTwo O's Avatar
Buy another 8mm socket, and drop it from a very similar location, and watch carefully where it goes. The first one you droped will be very close to the second one. This is how Huck Finn and Tom Sawyer did it!
The BIGGER question is, are you going to keep the engine tray off?
Old 06-19-2011, 11:32 AM
911Dave
911Dave's Avatar
Not really I've dropped plenty of nuts, bolts, washers, etc. but just was lucky enough to drop them where I could get them with other tools. In fact, if this was just a dropped nut, I wouldn't even both going after it. But an 8mm socket is worth a little more and I really don't want it rattling around in there.
Old 06-19-2011, 11:37 AM
911Dave
911Dave's Avatar
Yep, the engine tray is staying off. Or I might put it back on for winter driving to help keep the mag chloride off the bottom of the engine. Nasty stuff that mag chloride.
For your other suggestion, I think I'll use one of my less needed sockets for the experiment, like 4.5mm
Quick Reply: My 8mm socket fell into the crankshaft pulley area
