air bypass tube
Leon993. Damn look at all those dual cone filters with wire guaze! Thats alot of engines about to blow up! :-)....dont worry only teasing.
Heres mine with CF bypass by Gert - fitted perfect in 20 mins using a fresh 964 rubber shroud:
Rich. I have heat and I have air con but I cannot mix both at the same time any longer. I have low speed, I have just a bit more than low speed and I have fast and vert fast but nothing in the middle. I do not have defrost high speed any longer but I do not need it with high speed air con which seems just fine. On defrost it still works on the windows but doesnt supercharge - seems supercharged already on hi speed. The HVAC works absolutely fine in summer and shouldder seasons but in winter you have to manually cycle on long trips between a/c and heat to keep steamed windows at bay....thats the only compromise I have found...
Cheers
M
Cheers
M
