WB & NB Front Fenders, Are they the same?
I think the answer is yes but I have searched and cant find a answer for sure.
Are NB and WB Front fenders the same?
And the rear WB fenders are 2" wider in total then the NB Correct?
The width of the front fenders are the same as a NB. However, as mentioned in an earlier post where the rocker panel meets the bottom if the fender is where the difference lies. You can use a NB liner, as stated above, but there is a difference on that as well
Crome,
Those are the dimensions for the rear correct? Just to educate myself better the fronts are the same except for where the rocker meets the fender. I was under the assumption that only the quarter panels were wider on a S and Turbo car.
Mike
Mike
the 944 guy said 2 " wider in the rear
I was just replying to the , REAR
both front fenders r the same width
I just looked it up, 993 broschure
only 1995 has 272 hp
1996 thru 1998 c,s,s4,-282 hp & 11.3:1 compression ratio
tt-400 hp has 8.0:1 compression ratio
ts-430 hp
all has 3.6 liters engines
ts-430 hp
fenders are NOT the same:
NB fender: 993 503 031 01 $1,702
WB fender: 993 503 031 03 $2,197
Prices are from Pelican, I don't know what list is..
For those who were wondering, 997 NB/WB fenders are $400...
