key fob case replacement
I think I know the answer to this using the Search tool, but my question wasn't directly addressed. I have a key fob which works fine, except you have to push the button with two fingers to get it to work as its plastic case is cracked. The little battery is even exposed though it's secure. I bought a new plastic case at the dealer last week (stunningly dear at $92.) and started to replace the old plastic case with the new. I assumed the electronics within would just 'fall' out but they don't. I'm afraid I'll break something if I get too strong when prying them out so I"ve only tried that very tentatively. I'm thinking it may be easier if the battery were removed.
If the battery is removed do I have to worry about reprogramming the immobilizer? I'm thinking I don't but would like to be sure, as needless to say, I'm terrified at the prospect of that.
Thanks, NC. Like I said, I thought that to be the case. As far as being careful, I'll make the switch with the car in the garage in case it's there for awhile.
The memory of the signal for that specific fob is held in the immobilizer in the car, not the fob so no worries changing the battery in the fob. Even so, it's always a good idea though to leave the windows down when you're fooling on alarm stuff, just in case.
I bought a new key fob case three years ago and can not remember what I paid for it. Anyway, it is a simple operation to move the content from the old to the new key fob case. Nothing will be erased if you pick out the battery while you make the change.
Thanks, Robert. I took the battery out the other day to try and replace the case but couldn't get the little curcuit board out. It must be fused or something from being in there undisturbed for 16 years. I put a new battery in and put the old case back together and it worked fine as everyone said. I was very tentative when trying to get the electronics out as it seems so delicate. I don't suppose there is any trick to this that I'm missing?
http://www.suncoastparts.com/product...y_Code=993_key
I have the switch blade key not the key housing using the term from suncoast parts. Bought both the upper and lower key housing. As I remember it the curcuit board was loose once you screwed out the single screw that holding the two parts together.
http://www.suncoastparts.com/category/993_key.html
