Thoughts...HIDs on Ebay?
I have this exact kit... fit perfect, was installed in about 10 minutes.
http://cgi.ebay.com/ebaymotors/HID-H...item19c29231f8
here is an old thread: https://rennlist.com/forums/993-foru...ml#post3979688
the slim ballasts are 3x3.5 inches by 1.25 thick. there are pictures of the install in the above thread.
Currently fog lights, (after market turbo style vents) are used as daytime running light (Canada eh!)Any comments on running H3 conversion in Turbo vents (heat etc) because they will allways be on when the car is on. The stock lights that came with aftermarket vents cracked and burnt within a few months of install. I'm thinking they heat up so much that a car wash water was too much for them. It should'nt be the case but I don't know what else? Also, can a guy convert high, low and fogs to HID? Whats the downside (enough space) or just way to corny?
Very Easy to install, the bulb is slightly larger than OEM Bulb, so you just need to file a bit. Also need to bend the pin to hold the new bulb in place. The first install took about 20 mins to figure out. The second took 5
Looks really good! I think i'm going to get a set off ebay as well. Let us know if you find matching fog lights!
you get what you pay for IMO. My 5 year old japanese HID's houred out recently and after much research I plunked down $250 for a genuine Phillips kit (as good or better than most OEM's). Night and day difference (pun intended). Two thumbs way up for this upgrade.
http://www.philipshidkits.com/produc...ngle-Beam.html
