Thoughts...HIDs on Ebay?
Take a look a DDM Tuning. $30 for their lights. Also, I would go with 4500s.
http://www.ddmtuning.com/Products/Ap...Raptor-HID-Kit
you can get a better deal than that, just search HID H1 kit and maybe add the color temp to filter it down.
http://cgi.ebay.com/ebaymotors/HID-X...item19bd31ebcc
http://cgi.ebay.com/ebaymotors/HID-X...item33552865d3
http://cgi.ebay.com/ebaymotors/XENON...item56318153de
The last kit I bought I got for about $40 over 2 years ago. The kit I got for the 993 is about 4 years old.
Definitely look for the slim ballasts, then search the archives for HID installation.
One of the best value upgrades you can do.
Since the DDM bulb housing was a little too large for the opening in headlight I had to shave a little material away with a dremel. The pin that holds the bulb in place also had to bent to accommodate the HID unit. No big deal. Everything else, cables, ballast etc slots neatly into the headlight unit. Its a very clean install.
I would doubt the raptor will fit. It was tight enough in there even with the slim ballast. There's quite a lot of wiring, a capacitor(?) and the ballast to manoever around quite a small space, plus get the housing cover to slot into place. Maybe with careful wire organization it might....
