View Poll Results: Have you experienced a broken distributor belt?
Yes
15
7.50%
No
185
92.50%
Voters: 200. You may not vote on this poll
How many have broken their distributor belt?
#106
As mentioned by others, Bosch will not sell the special bearings as confirmed now with this reply:
Bei den Kugellagern zu dem Tandem-Zuendverteiler handelte es sich
um eine Spezialanfertigung von Fa. INA. Leider können wir Ihnen diese
jedoch nicht zum Kauf anbieten.
Sie haben jedoch die Möglichkeit einen Austausch Zuendverteiler zu erwerben.
Bestellnummer 0 986 237 900.
Mit freundlichen Grüßen / Best regards
Jürgen Gräber
Robert Bosch GmbH
Automotive Aftermarket
Sales Europe Central
Kundenberatung (AA/SEC3)
Postfach 41 09 60
76225 Karlsruhe
GERMANY
Jürgen Gräber
Robert Bosch GmbH
Postfach 41 09 60
76225 Karlsruhe
GERMANY
Günter,
I just came across Bosch's reply.
My reply to them:
Bosch können meinen arsch küssen, wenn sie denken dass ich einen umgebauten Verteiler kaufe wenn ich nur einige kugel lager brauche.
Translation: Bosch can kiss my *** if they think I am going to buy a rebuilt distributor when all I need are a few bearings.
I guess they won't be selling too many rebuilt distributors in the near future, especially with a NOS distributor sitting on my shelf. Some companies aren't too swift. When there is a need for something, someone else will step in.
#107
That's funny, Alex.
The problem remains.
When one discovers a seized bearing, where does one get a new one?
You get a call from a mechanic that the bearing is kaput and then what? Most likely a shop will send for a replacement or rebuild from Bosch or?
These twin-distributors are getting older all the time and instead of concentrating on the belts, one needs to concentrate on the bearings. If a bearing is seized to the point of galling the shaft, one is up the proverbial creek.
IMHO, a distributor with 100-150k miles need to have all bearings replaced and that will cost 4-500 if a shop does it or if Bosch does it. It's delusional to just replace the belt and think all is well.
If you can sell the bearings eventually to DIY's, great, but what can people do that don't have the skills to do it? They'll have to send the twin out to somewhere.
Go for it, Alex, produce the special bearings. The needle bearing on the bottom of the primary shaft seldom fails because it gets a bit of engine oil but it is easily available .
#108
1 - Just replace the distributor function - based on rotation of the distributor, fire certain plugs. Since the distributor is a mechanical device, not much logic should be in place
2 - Replace the plug wires and install coil packs, and have those triggered. The coil packs will be interesting, especially for some of them with very low clearances -
I have not done much research here (yet).
Cheers,
Mike
#109
You better believe I will. Bosch made me do it!
I just ordered the actual INA brand bearing. They are quite reasonable. No promises as to when. Its too bad my car isn't down with bad DZV bearings or I'd be right on it. I have other things on the go.
#110
Technical Guru
Reviving this thread...
After reading through the various Gates catalogs I'm not sure that the PowerGrip XL belt that everyone is installing is the correct belt. They sell lots of ozone compatible belts, the 114XL is not one of them? The Contitech CT1032 is ozone compatible! Porsche installed vent kits on all the distributors in the field but (more importantly) they changed the spec on the belt material for all future distributors.
1995, 1996, 993, belt, broken, c2, distribute, distributer, distributor, distributot, drive, duel, porsche, problems, test
