What size flare nut wrench to bleed brakes?
Sorry for the dumb question, but I am about to place a tool order and thought I could add a good flare nut wrench. 7mm? 11mm?
I use my flare wrench because I found the clearances to the caliper were too small for my regular wrenches. You likely have nicer tools than I .
11mm for calipers .... but don't forget the 7mm for the clutch slave cylinder - for the complete bleed set : box ends work well, though a flare would do as well.
11mm, just did my rear today. Personally I use a 6 point 1/4" drive (deep) socket to break the bleed screw loose and then use what's usually called a Ignition Wrench (very small wrench set) to open and close the bleed screw. Then use the 1/4" drive socket to snug the screw back up.
I have 3 sets of ignition wrenches and they all came from Sears (Craftsman).
Thanks guys. I knew I didn't need a flare nut wrench for the bleeding, but knew it was an odd size and thought I could go ahead and get the correct one in case of any other brake work.
