Returning my seats to newish condition without dye...
#31
http://www.leatherique.com/do_it_you...irections.html
#32
Leatherique also sells dyes and custom mixes if needed. I have their dye kit which comes wit cleaner and conditioner as well. Have not used it yet, though.
#33
It works great.
Their conditioner is called "Soffener" http://www.colorplus.com/frameset_products.html
The people at Color Plus are GREAT to work with. No affiliation... but I use their stuff often.
Actually repairing, redying and conditioning a pair of hardback sport seats to go in my turbo right now
#34
If all you need detailed are the seats, it is a very easy DIY job with leatherique rejuvinator oil and pristine clean. I do this myself. I had a 95 M3 steering wheel that looked like the leather was shot. Using the oil and a soft tooth brush, it turned out to be caked on dirt. The wheel came out like new. I have been sold on the stuff since then.
This was the first time I've visited their shop though I've been wanting to check it out for awhile now. Very impressive staff and facility.
EDIT: Forgot to mention, even thought there was beautiful white GT3 and flat-out awesome dark grey 430 Scud in the driveway every one of the crew stared at my car as I drove in and they stared at it like it was something special. (Or maybe they were just blown away at how filthy it was.)
#35
It's very easy to clean up, & all NWAS products can be purchased online.
Dye transfer is very common, especially on lighter colored leathers, but usually it's on SUV's where people slide in & out of the car. If you keep on top of the problem it's a simple fix, it's when it's been years in the making, that it can be hard to remove. I have some leather cleaners that will remove dyes easier & faster, but you can't beat leathereique for neglected leathers.
When you are buffing a 993 it's best to remove the bumperestts, headlights, & badges. There is a TON of dirt that gets stuck under them.
But NWAS does good work & you can't go wrong with their higher end details.
Anyone local that needs 993 detailing advice, I cam more then willing to help out.
#36
FYI many of you were right and it has already been mentioned here. I asked Blake at NWAS what they used on my car and it was leatherique left on overnight. If nothing else, I learned something. Leave the stuff on for 24 hours and wipe off next day.
#39
Any more pics of your car? It looks awesome!
![](http://i226.photobucket.com/albums/dd155/lpm505/105abc.jpg)
#40
As for cleaners, truly good cleaners are those that do the job extremely well while also being safe to use over and over again in the long term without damage to the finish. And they're even better when they are priced low compared to those specialty cleaners that are grossly overpriced.
There is nothing magical about detailing; its using the right products, a method and time/patience. IMO, a car cannot be properly detailed in a day.
#41
I can't comment on its use on leather, but I can on its use on exterior plastics such as fairings and windscreens of motorcycles. Lemon Pledge makes the bugs so much easier to remove at the end of the day.
If Pledge was the miracle for cars, it would already be rebranded & for sale in the car detail product isles.
#42
Using "pledge" on cars is a Hot Rodder thing. It does clean & make things shine, but it's NOT for cars, & there will be issues with long term use. At car shows I see a ton of pledge, & the new thing is the wipes. While fine for a spot clean, it is NOT a car cleaning product, & over time, & will damage paint, & leather. It will pull all the oils & suppleness out of the leather over time.
#44
But there are some products that you will not find in the car isles that are far better and far cheaper.
#45
I should have mentioned that I've used Lemon Pledge since 1991 on my 1990 BMW motorcycle that I bought new back then and to this day there is absolutely no damage to the paint. In fact, I'd like to see someone else with an original finish as good as mine on a vehicle of that age.
I'll rise to that challenge.
I've been using Lemon Pledge for that long on my bikes as well.
It also works great on plastic instrument covers, lenses, and windshields. It helps hide fine scratches.
Here is a shot of my trio of Yamaha six-speeds. Two '90, and a '89. Recognize them?
![](http://webpages.charter.net/cemoto/ebay/123RZaa.jpg)
Regards,
Al
