993 Forum 1995-1998
Motec conversion - Almost there
Old Nov 16, 2011 | 11:42 AM
  #31
Juha G's Avatar
Juha G
And it feels good too!!!
Old Nov 16, 2011 | 12:35 PM
  #32
Flying Finn's Avatar
Flying Finn
King of Cool
Awesome result Jussi!!! There's still no snow so I think it's time for you to head to Alastaro and get some times...
The question now is... How long will it make for you to make me one? Our engines are very similar (with sport cats and all) so hopefully I could use the same maps.
Colin, you think that would be possible (to use same maps and get close results)?
Old Nov 16, 2011 | 02:48 PM
  #33
NineMeister's Avatar
NineMeister
The beauty of Motec is that it is easy to re-tune the ecu once the engine is running properly, so the real benefit of starting with Juha's file (like Juha started with a 9m file) is that you will be able to put a safety trim on the ignition and run the engine under partial load on the dyno immediately and dial in the fuel table. With the fuel table close to optimum you go back to ignition and take out the trims, then fine tune the fuel again. So the answer is no, you can't use the same maps for cars in a different country at different temperatures on different fuel, but it will be very close.
That said, I would be very surprised if the car did not show similar % gains, irrespective of the actual measured dyno numbers.
Old Nov 16, 2011 | 03:10 PM
  #34
Flying Finn
King of Cool
Thanks Colin, that's good news. Now I just need to "convince" Juha to make me one with some Finnish Vodka next time I see him...
Old Nov 20, 2011 | 11:15 PM
  #35
trophy's Avatar
trophy
That is a great result Juha....
