Tired of what you have to go through to properly jack up a 993 without a lift or scissor jack
The cost to raise my 993; It looks like a 2 pole lift is around $1,400. A scissor lift is about $1,500.
I have noticed in many of the posts, garages equipped with a scissor jack, or a 2 pole lift. I am curious what someone that already has a lift of some type would recommend me to get??
I would like to be able do normal service including engine or suspension removal. Need the proper equipment to start down that slippery slope!!
How much headroom do you have...that is the usual driver for the difference.
You can get a full sized two post lift (needs the most room), a shorter two post lift, a "portable" two post lift, and scissor lifts. You have to look at specific needs to know what to look at.
Not sure where you are getting a good two post lift for $1400 - however I have a 9000lb two post in my shop. Its way overkill for a 993, but I had two reasons: One is I have other vehicles that I want to lift, and one is a full sized truck with a power tailgate and utility box, and the other is margin of safety - I often have friends/buddies over, and I would like the lift to be as strong as practical while we all stand underneath a 3000+ lb vehicle.
My lift was supplied by Greg Smith Equipment - can highly recommend them. However, you will get numerous opinions on which ones are best.
I do it all on the floor. Sure, not as easy as the torsion bar era cars, but it doesn't add that much time--5 to 7 minutes to get the car up in the air? if I were doing it pro again with a body pushing 50, different story.
My garage has 10 foot ceilings; I assume if you have the room a 2 pole lift would allow the most access to working on the car, is that correct????
My ceilings were 10-'6" and I could stand underneath the car, and I am 6'.. It was quite workable. Yes, the two post (not pole) lift allows for the most access. You should get a floor jack to work with the lift for those times that you need better access (like doing an oil change).
I just finished rebuilding the shop and added a raised roof section, I now have 14' over the lift!
I've got 15 ft celings so my 2 post Rotary lift has room to spare and I can't be more pleased with it. Not sure how one would work with 10' ceilings, but per Mike's post it sounds like a 2 post is doable.
A 2 post is by far the best lift for working on the car. You'll find 2 post lifts at the service departments at the dealerships.
